Removing Paint Spots. Help!!
Old May 14, 2008 | 07:01 PM
Cayman's Avatar
Well I picked up my car a couple weeks ago and had it parked at work. Some stupid workers decided to paint the cieling in the car garage near my G and now I have some tiny white paint spots on my hood; any idea how to remove these? Will clay work?
thx!!
Old May 14, 2008 | 07:36 PM
TheIvoryG's Avatar
I'd start with a good wash, then go directly to clay. That should take care of it. After that, go to the workers(or prop) mgt and tell them how stupid it is to paint the ceiling above a parked car without covering it.
Good luck.
Old May 14, 2008 | 07:41 PM
MixturePinoy's Avatar
have work pay for it
Old May 14, 2008 | 08:10 PM
Detailed Image's Avatar
Using a clay bar on your paint should do the trick. Sometimes on paint overspray, you may want to use a medium grade bar instead of a fine grade bar. Keep in mind, a medium grade bar will remove the paint spots faster, but can often cause micro-marring in your paint that requires a polish afterwards to remove. Regardless which clay you use, follow up with some protection from a sealant and/or wax.
George
Old May 22, 2008 | 09:17 AM
Cayman's Avatar
Okay, so i've tried using the clay bar but the white paint spot are still there.
Any other ideas to get them removed?
Old May 22, 2008 | 09:59 AM
RBull's Avatar
Rated M
^the clay with some lubricant should work. Just work at it.
Danielek
May 1, 2022 01:28 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
cmesidewayz
Sep 29, 2015 09:28 PM
