Orange Peel Help!
Old May 23, 2008 | 03:53 PM
adog35's Avatar
Orange Peel Help!
How do you get rid of orange peel with out color sanding your car? People say over time as you keep waxing it is that ture?
Old May 23, 2008 | 03:59 PM
Detailed Image's Avatar
Color sanding is really the only effective way to remove orange peel. Waxing will do nothing, it's non abrasive. You can compound with a rotary buffer (wouldn't recommend this unless you're highly experienced) but bottom line, you need to wear away your clear coat with an abrasive substance (sand paper, compound, etc.). Personally, I'd just live with it. Nearly every car has some degree of orange peel.
Hope this helps.
George
Old May 23, 2008 | 05:47 PM
kenchan's Avatar
orange peel is good when you get a ding. the PDR tech will hide the
ding inside the peel. it's there to hide imperfections.
color sanding? i call it wetsanding...
Old May 24, 2008 | 06:05 AM
TOGWT's Avatar
"color sanding? i call it wetsanding..."
Years ago it was called colour sanding because automotive paints were single-stage (primer and a colour coat) and when the finish faded from ultra violet radiation (UVR) exposure, sanding off the oxidized paint thereby exposing the underlying paint would bring back the paint surface colour.
Then, as now, most sanding was done wet so the terms colour sanding, wet sanding and as all these process involves a sanding block, block sanding all became interchangeable whether you are sanding the colour coat (colour-sanding) or the clear coat (wet-sanding) to produce a level paint surface.
tiguy99
Mar 1, 2016 11:42 AM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
emorehs
Jul 17, 2015 09:45 AM
