Save ~30% or more EVERYDAY at DetailedImage.com!
Today's Daily special (August 6, 2009) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.49!
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (August 7, 2009) is P21S Finish Restorer.
Regular Price for 75 ml is $9.99. Today's price is $8.27!
- Clean, restore and polish your wheels and metal trim in one easy step
- A little goes a long way, work a small amount of product into the metal with light pressure
- We recommend using a foam applicator pad for application
- Use a polishing towel to remove excess product and to buff to desired finish
Today's Daily special (August 10, 2009) is Grit Guard Grit Guard Insert.
- A must have for any detailer, minimize adding imperfections during the wash phase
- Simply place the Grit Guard insert into the bottom of a bucket to trap dirt and contamination
- Gently glide your wash medium over the Grit Guard insert to release contamination
- Excellent results with the Lake Country Grout Sponge paired with a Grit Guard bucket insert
Today's Daily special (August 11, 2009) is Clear Kote Quik Shine (QS).
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 32 oz is $16.99. Today's price is $12.74!
- An amazing quick detailer that not only enhances the gloss and depth but also cleans the paint
- Ideal for removing a coating of light dusting on your paint or for boosting gloss after a wash
- Works great as a clay bar lubricant
- Use a plush microfiber towel to minimize adding imperfections and to prevent streaking
Today's Daily special (August 12, 2009) is Optimum (OPT) Hyper Compound.
Regular Price for 32 oz is $19.99. Today's price is $14.99!
- A great compound that offers long work times and can be used in the sun or shade
- Most commonly applied with a yellow cutting pad or purple foamed wool pad when using a buffer
- Popular amongst mobile detailers who may be polishing outside
Today's Daily special (August 13, 2009) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
- Our most cutting pad option, however, due to the wool strands, not as much heat is generated
- Works best on high powered buffers, for fast, effective paint correction
- Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (August 14, 2009) is Chemical Guys Citrus Wash & Gloss.
Regular Price for 16 oz is $7.99. Today's price is $5.99!
Regular Price for 128 oz is $22.99. Today's price is $17.25!
- One of our best selling shampoos, lots of foam, great lubricity, strong cleaning power
- Can be used in high concentration to strip off previous coats of protection from a sealant or wax
- Can be used very diluted to maintain your coats of protection during regular maintenance washes
- Works great in a foam gun, such as the Gilmour Foamaster II
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (August 15, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
- One of the most durable hoses available with the thick 8 ply construction
- Minimize kinks that slow down water flow
- Full LIFETIME Replacement from Gilmour ensures complete satisfaction
Today's Daily special (August 16, 2009) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
- A Dodo Juice hard carnauba wax designed to work exceptionally well on lighter colored vehicles
- Extremely easy to apply and remove, especially when applied in thin layers
- Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
- Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
- Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (August 17, 2009) is Lake Country Black Finishing Pad.
- A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
- Also can be used to apply a paint cleaner, glaze or sealant
- Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
Today's Daily special (August 18, 2009) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.49!
- Foam based formula that is ammonia free, making it safe on tinted windows
- Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more
- Best applied with an all purpose microfiber towel, then wiped clean with a dry microfiber towel
- For optimal results, give a final wipe down with the low nap, glass microfiber towel
- Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Today's Daily special (August 19, 2009) is Lake Country Ulti-Mit.
Regular Price is $15.99. Today's price is $11.99!
- A paint safe foam wash mitt that has two different surfaces to tackle various areas of your vehicle
- Holds large amounts of suds and water which helps minimize marring the paints finish
- Use the red cubed side to wash your paint, as it is the softer of the two sides
- Use the black side to clean stubborn contamination off of lower panels, tires, wheel wells and more
- Highly recommended to be used with a Grit Guard insert to easily release contamination
- Will outlast natural fiber mitts due to the durable foam design
Today's Daily special (August 20, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
- Water based tire dressing that applies easily and does not sling onto your paint
- Can be applied in multiple layers for a glossier look or buffed down to a matte finish
- We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Today's Daily special (August 21, 2009) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
- Remove embedded surface contamination that does not come off during the washing process
- Medium grade bars will remove contamination quickly, however it may result in micro-marring
- Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
- Helps you get the most out of any step you perform after using the clay bar
- Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
- We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Today's Daily special (August 22, 2009) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.49!
- Perfect maintenance shampoo that enhances gloss and depth
- Lots of lubricity and slickness to help minimize adding imperfections
- Concentrated formula means only a little product is needed per wash
- Best used with a grout sponge or sheepskin wash mitt
