Save ~30% or more EVERYDAY at DetailedImage.com!
Old Oct 9, 2009 | 11:10 AM
  #421
Detailed Image's Avatar
Today's Daily special (October 9, 2009) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.87!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Old Oct 11, 2009 | 07:32 PM
  #422
Today's Daily special (October 11, 2009) is Menzerna PO106FA Nano Polish (Super Finish).
Regular Price for 16 oz is $26.99. Today's price is $20.82!
Regular Price for 32 oz is $49.99. Today's price is $37.49!
Regular Price for 128 oz is $149.99. Today's price is $123.00!
  • Our best selling finishing polish that removes light imperfections and lots of depth and gloss
  • Easy to work with, with long work times and easy removal when properly broken down
  • Most commonly applied with a white polishing pad for a great combination of cut and gloss
  • Can also be applied with a black or blue finishing pad for additional depth and gloss but less cut
Old Oct 15, 2009 | 04:26 PM
  #423
Today's Daily special (October 15, 2009) is Menzerna Power Gloss.
Regular Price for 16 oz is $18.99. Today's price is $14.24!
  • One of our most aggressive compounds we have to offer, allowing for deep paint correction
  • Most commonly used on a yellow cutting pad or purple foamed wool pad
  • Will leave behind marring and hazing, so it is important to follow up with a less aggressive polish
Old Oct 16, 2009 | 12:24 PM
  #424
Today's Daily special (October 16, 2009) is Dodo Juice Time to Dry Drying Detailer.
Regular Price for 250 ml is $12.99. Today's price is $9.74!
  • Dry your paint faster and more effectively
  • Helps minimize adding imperfections during wipe downs
  • Reduce potential water spots on your paint
  • Best used in conjunction with a waffle weave drying towel
Old Oct 18, 2009 | 08:04 AM
  #425
Today's Daily special (October 18, 2009) is Menzerna PO85RD Polish.
Regular Price for 32 oz is $39.99. Today's price is $29.99!
  • When you want the absolute maximum depth and gloss, finish your polishing with PO85RD
  • Works best after correcting paint imperfections with more aggressive polishes
  • Most commonly applied with a black or blue finishing pad when used on a buffer
Old Oct 19, 2009 | 07:53 PM
  #426
Today's Daily special (October 19, 2009) is Optimum (OPT) No Rinse (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.15!
Regular Price for 128 oz is $39.99. Today's price is $31.81!
Regular Price for 8 oz is $7.99. Today's price is $5.99!
  • One of the must haves for any auto detailing enthusiast or professional, simply revolutionary
  • ONR is perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
Old Oct 20, 2009 | 07:11 PM
  #427
Today's Daily special (October 20, 2009) is Clay Magic Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Fine grade clay bar that is one of the standards in the industry for enthusiasts and professionals
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Oct 21, 2009 | 09:59 AM
  #428
Today's Daily special (October 21, 2009) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Oct 22, 2009 | 03:07 PM
  #429
Today's Daily special (October 22, 2009) is Chemical Guys Vertua-Bond 408.
Regular Price for 16 oz is $26.99. Today's price is $20.24!
  • Properly preps your paints surface for applying a sealant or wax to your paint
  • Ensure you achieve the maximum durability out of your protection by using Vertua-Bond 408
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Old Oct 25, 2009 | 04:31 PM
  #430
Today's Daily special (October 25, 2009) is Chemical Guys Window Clean.
Regular Price for 16 oz is $5.99. Today's price is $4.49!
  • A tint safe window cleaner that cuts through grime and leaves windows streak free
  • Best applied with a microfiber towel and followed up with a glass microfiber towel
Old Oct 26, 2009 | 08:12 AM
  #431
Today's Daily special (October 26, 2009) is Poorboy's World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
  • Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
  • Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
  • Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
  • For easy dilution and usability, we recommend a 22 oz spray bottle
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Old Oct 27, 2009 | 01:05 PM
  #432
Today's Daily special (October 27, 2009) is Poorboy's World Leather Stuff.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
  • An amazing one step solution for leather. Cleans, lightly conditions, and UV protects!
  • Restores and leaves behind a pleasant leather scent
  • Easy to apply and remove, while leaving behind a like new matte finish
  • Also works well on vinyl and rubber surfaces throughout the vehicle and home
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Old Oct 28, 2009 | 02:18 PM
  #433
Today's Daily special (October 28, 2009) is Optimum (OPT) Opti-Bond Tire Gel.
Regular Price for 128 oz is $35.99. Today's price is $27.81!
  • Gel based tires dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Old Oct 29, 2009 | 03:19 PM
  #434
Today's Daily special (October 29, 2009) is Klasse All In One (AIO).
Regular Price for 500 ml is $27.99. Today's price is $21.28!
Regular Price for 1000 ml is $39.99. Today's price is $30.40!
  • A must have for anyone looking for an all in one (AIO) product that cleans and protects
  • A strong chemical cleaner that can remove oxidation, water spots, and other surface imperfections
  • Leaves behind an acrylic layer of protection that lasts months
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Can be applied with a foam applicator pad and removed with a quality microfiber towel
  • When using a buffer, best applied with a white polishing pad or black finishing pad
Old Oct 30, 2009 | 07:30 PM
  #435
Today's Daily special (October 30, 2009) is Menzerna Finishing Touch Glaze (FTG).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $23.99. Today's price is $17.27!
  • A glaze that utilizes kaolin clay and oil fillers to help improve the depth and gloss of your paint
  • Can mask minor surface imperfections in the paint
  • Most commonly applied with a black finishing pad when used on a buffer
