Save ~30% or more EVERYDAY at DetailedImage.com!
Old Aug 24, 2009 | 05:37 PM
  #391
Detailed Image's Avatar
Today's Daily special (August 24, 2009) is Chemical Guys M-Seal Pure Sealant.
Regular Price for 16 oz is $19.99. Today's price is $14.99!
  • One of the best bang for the buck, pure sealants for under $20
  • Easy to apply and remove when applied properly, which is as thin as possible
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Old Aug 25, 2009 | 09:16 AM
  #392
Today's Daily special (August 25, 2009) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.99!
  • Designed to remove a majority of imperfections in the clear coat
  • Removes moderate to deep swirls, oxidation, water spots, scratches and other imperfections
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
  • When using a buffer, best applied with an orange light cutting pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old Aug 27, 2009 | 07:41 AM
  #393
Today's Daily special (August 27, 2009) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Old Aug 28, 2009 | 03:04 AM
  #394
Elie JAMES's Avatar
WOw.........Great
Old Aug 28, 2009 | 09:03 AM
  #395
Today's Daily special (August 28, 2009) is Optimum (OPT) Metal Polish.
Regular Price for 8 oz is $9.99. Today's price is $7.49!
Regular Price for 32 oz is $32.49. Today's price is $24.37!
  • Polish your metal to a high level of depth and gloss with the Optimum Metal Polish
  • Apply with a foam applicator pad and remove with a quality microfiber towel
  • Most commonly used on wheels, exhaust tips, interior and exterior metal and chrome trim
Old Aug 31, 2009 | 05:07 PM
  #396
Today's Daily special (August 31, 2009) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
Regular Price for 32 oz is $22.99. Today's price is $17.24!
Regular Price for 128 oz is $54.99. Today's price is $41.24!
  • Strong UV protection on vinyl, rubber, leather and plastic
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, and leather seats
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Old Sep 1, 2009 | 08:44 AM
  #397
Today's Daily special (September 1, 2009) is Poorboy's World Trim Restorer.
  • Restores faded, neglected trim that has been over exposed to the elements
  • Works best on rubber, vinyl and plastic trim
  • Apply thicker for some gloss or buff dry to desired matte finish
  • For maximum results, prep the surface you plan on restoring with a degreaser like Total Auto Wash
Old Sep 2, 2009 | 05:18 PM
  #398
Today's Daily special (September 2, 2009) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.49!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old Sep 5, 2009 | 04:04 PM
  #399
Today's Daily special (September 5, 2009) is Chemical Guys Hose Free Eco Wash.
  • Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
  • Environmentally friendly
Old Sep 6, 2009 | 12:24 PM
  #400
Today's Daily special (September 6, 2009) is Poorboy's World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
  • Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
  • Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
  • Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
  • For easy dilution and usability, we recommend a 22 oz spray bottle
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Old Sep 7, 2009 | 12:13 PM
  #401
Today's Daily special (September 7, 2009) is Chemical Guys Wheel & Rim Citrus Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.74!
  • Citrus based wheel cleaner that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it down 7:1 with water
  • Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
Old Sep 9, 2009 | 02:03 PM
  #402
Today's Daily special (September 9, 2009) is Lake Country 4 Inch Orange Light Cutting Pad.
Regular Price for 4" is $4.99. Today's price is $3.74!
  • A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
  • Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Sep 11, 2009 | 10:18 AM
  #403
Today's Daily special (September 11, 2009) is Poorboy's World Spray & Gloss (S&G).
Regular Price for 32 oz is $14.99. Today's price is $11.24!
  • Best used after a wash to increase the depth and gloss of any color paint
  • Helps extend the protection of sealants and waxes
  • Easy to apply and remove without streaking when applied correctly
  • Not only works well on paint, but glass, chrome and other areas of your vehicle.
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Old Sep 15, 2009 | 09:37 AM
  #404
Today's Daily special (September 15, 2009) is Clear Kote Carnauba Moose Wax.
Regular Price for 16 oz is $18.99. Today's price is $14.24!
  • Easy to use carnauba wax that is in a non-paste form
  • Leaves behind lots of gloss and depth and provides weeks of protection
  • Can be applied with a buffer using a blue pad
Old Sep 17, 2009 | 03:22 PM
  #405
Today's Daily special (September 17, 2009) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 16" is $7.99. Today's price is $6.05!
  • Thickest, softest, most plush towel we carry.
  • Over 3x thicker than regular microfiber towels.
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
