Confused about Sonus Acrylic Spritz
Apr 23, 2004 | 07:55 PM
OK I am confused. The Perfect Shine recommends putting P21S carnauba wax as a last step after using the Klasse sealant. It then suggests the Sonus Acrylic Spritz as a touch up when necessary. However, the Sonus Acrylic Spritz bottle says - NOT RECOMMENDED FOR USE WITH CARNAUBA WAX FINISHES. What gives? How can I use the acrylic spritz over the P21S wax coat?
Reply 0
Apr 23, 2004 | 10:00 PM
Re: Confused about Sonus Acrylic Spritz
Sonus also makes a carnauba detail spray.....I think they mention that as well but its not highlighted like the acrylic spray....(I believe they don't sell it on that site)
I haven't tried the acrylic spray on or over wax yet....but I think maybe just do a sample or test area and see if it has any problems streaking or hazing.....If the P21S can be used over the Klasse without a problem, I don't see why you couldn't put acrylic spray over the wax.............
If it is a problem,
When I do a top coat of P21S, I will probably just use regular detail spray to enhance the shine.....
Dennis
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Reply 0
Apr 24, 2004 | 12:13 AM
I would personally use (and do personally use) One Grand Show-Off or Einman Fabrik Clear Pearl detail sprays over carnauba wax.
Reply 0
