Hazy Lights >:-(
Old Sep 3, 2008 | 03:58 PM
yourdoinitwrong's Avatar
Had the same thing on mine
My headlights had a haze on them as well and I bought Meguiar's Plastic Cleaner & Polish and it took care of it. I did it by hand and it worked fine but I imagine a buffer would be better if you have one. If you use the Meguiar's make sure the lenses are cool, use light pressure, and use a separate towel to wipe if off right away. Might take a few times but it ended up looking pretty good. Hope that helps.
Old Sep 5, 2008 | 02:46 AM
jutn35's Avatar
G35 Coupe
Originally Posted by InLU
Here ya go justin before and after shots. I used the orbital and polish on mine as well.
loosk great, i practiced on my moms Acura and its like what u just showed me
Old Aug 17, 2009 | 01:47 PM
da champ's Avatar
This looks very helpful...
Old Aug 17, 2009 | 02:42 PM
4zero6's Avatar
This:
http://meguiarsdirect.com/detail/MEG+G12310
Plus this:
http://www.mothers.com/02_products/05140.html
With a little work= 100x better.
Did it yesterday and was impressed with the results.
Old Aug 18, 2009 | 09:29 AM
Detailed Image's Avatar
Here's a good step-by-step tutorial on how to restore headlights.
If the lights are in decent condition, chances are you can get away with simply polishing. If the lights have been neglected and you really want to restore them, you can opt to wet sand the lens and follow up with a polish for maximum restoration.
If anyone has any questions, please do not hesitate to ask.
George
Old Aug 21, 2009 | 01:39 PM
hg35x's Avatar
I like the toothpaste idea - I've used it on my oak table that had white water spots on it and it worked great.
Old Aug 23, 2009 | 12:01 AM
Xet's Avatar
Xet
dang just used my pc on mine today with mezerna ip followed by fp and then a sealant and wow it looks amazing. if you have a pc, use it period! it takes almost no effort and the results are amazing
Old Aug 23, 2009 | 12:52 AM
thescreensavers's Avatar
Mr.202?
I used some M105 on an LC Orange Pad and did absolutely nothing other then take off a spot of paint I been trying to remove by hand forever lol.
Old Aug 23, 2009 | 02:38 PM
Darkstar752's Avatar
M105 works by pressure since it has non-diminishing abrasives, so make sure you are using a good amount of pressure. If you are, and it's not clearing up the headlights, it's possible the inside has hazed.
I did a sedan headlight yesterday, and it took maybe 20 seconds to clear it up with a less aggressive combo than you were using.
Old Aug 23, 2009 | 02:53 PM
Xet's Avatar
Xet
granted i wasnt using the same polish but mine came off with ease as soon as i turned it up to 6k rpms. are you sure your imperfections are on the outside and not the inside? which you would have to bake and open to fix..
Old Aug 23, 2009 | 09:29 PM
aaron.burks's Avatar
wetsand plus polish
Old Aug 23, 2009 | 09:35 PM
Mr.202?
This I am not sure, I think I will be painting my headlights so when I open them ill clean the inside. I took my DA (G110) to 6k and was putting a bit more pressure then before and absolutely nothing. I though I might of put too much M105 and it was lubricating and not really cutting so I cleaned what was on my lens had a little bit left on my pad and put a pea size drop on the pad and worked it in for a bit, it was started to powered so I worked it enough and absolutely no difference.
I cant feel anything on the outside is smooth, My lens has a light yellow haze to them and when the lights on they look like InLU's. Gerr want to clean them lol. I Might need to sand them. If I paint them Ill buy the the 3m lens restoration kit from Ace hardware if cleaning inside doesn't work.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
