Help..swirl scratches after using a 'gritty wax'..best way to fix?
Old Aug 27, 2008 | 11:43 PM
gwhizz35's Avatar
So my friend swore by this wax called G10, it's made somewhere in Europe.
He told me to use it as a cleaner wax first with an orbital.
After I used it...I saw major swirls on my car. It's Obsidian Black by the way.
certain parts almost looked 'gray-faded'. This is under fluorescent light in the garage.
Any ideas how to get this out?...am I screwed?
Let me know your thoughts.
Thanks
Old Aug 28, 2008 | 12:36 AM
TheIvoryG's Avatar
I've never heard of it, but a wax gave you swirls? And he recommended using a wax with an orbital? Something just sounds wrong here to be honest with you.
I doubt you are screwed, but you have some work ahead ofyou. You need a good polish job at this point I'm assuming, but hard to tell without pictures. Doesn't sound like you used a true wax, unless it was a wax that was "gritty" because there was literally dirt in it. Polish, get the scratches out, then throw that wax away. Follow up with a quality LSP...
Old Aug 28, 2008 | 12:45 AM
gwhizz35's Avatar
Thanks Ivory..I know..I wanted to post pics, but b/c of the fluorescent lighting and the black color, it just doesn't pick up what I'm talking about very well.
Should waxes not be applied with an orbital or rotary of any kind?
All by hand?
What's an LSP?
I'm thinking of using some of the Klasse cleaner wax and then polish I have to see if that'll work. I usually put it on by hand and then take it off with an orbital.
Old Aug 28, 2008 | 10:43 AM
merlin3008's Avatar
Sounds like you have hazing as a result of a course polish. From what I can see on the web, G10 is not a wax at all. They have couple of different polishes, but i can't fined any with a protectant. Personally, I would find a finer grade polish and go over the whole car. But a good lesson here is to always try out a new product on a smaller area of a car before going at it. If the swirls are pretty bad, I would go with something like a Menzerna IP and FP to get rid of the haze and finish it off. It's going to be work. Unfortunately, it's harder to remove swirls than it is to make them.
What machine did you use to polish the car?
Old Aug 29, 2008 | 03:15 PM
blueboxer's Avatar
Is the g10 a heavy cutting polish or rubbing compound? What pad did you use with the buffer? You can try to remove the hazing and swirls with Ceramic Clearcoat Polish. If that doesn't do it you might have to start with Power Gloss and then the PO106ff. If you only want to do local stuff, try and pick up some Meguairs Swirl Remover 2.0 and maybe finish up with Meguiars Machine Glaze #3. I would test all future products on a test panel or small section before doing the whole car.
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 11:25 PM
bigmike
Sep 17, 2015 01:58 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
