Headlight Cleaning
Old Sep 2, 2008 | 01:58 PM
Fri Guy's Avatar
Headlight Cleaning
I need to clean the headlights on my fiances coupe. Would something like this kit be good to use or is there a better/cheaper way of doing it? I tried Plastic X by hand & it helped but still didn't come out that great. I don't have a buffer/polisher but I do have a cordless drill. Thanks for any advice!!!
http://www.autogeek.net/plastik-lens-cleaning.html
Old Sep 2, 2008 | 02:22 PM
jutn35's Avatar
G35 Coupe
all i used was a Turtle Wax paste polish, and an orbital buffer, some one on here told me that Colgate Toothpaste is good to use as well, i havent done it yet, but using regular polsih or wax will do the job
Old Sep 3, 2008 | 03:05 AM
Scrooge's Avatar
Your really not going to get a A+ job without a buffer.
Old Sep 4, 2008 | 08:18 AM
Fri Guy's Avatar
Here is what I plan on doing. Wet sanding with 1500, 2000 then hit them with PB SSR 2.5 with a orange pad. Next wipe off & hit them with the same pad & some PB SSR 1. Then spray some Plexus & wipe off. Do you think it will work o.k.???
Old Sep 7, 2008 | 04:28 AM
gtbigup01's Avatar
What doyou do when the hazing is on the inside of the lens?? I guess it stay s there as there is no way to clean them.
Old Sep 7, 2008 | 02:00 PM
jutn35's Avatar
G35 Coupe
oo u can clean them , u just have to pry it open which would take an hour for someone new to it.
Old Sep 7, 2008 | 03:05 PM
G_whip's Avatar
wtf haze on the inside that sucks never heard of that before but like you said before wet sand is the best way use 1500 at first build up a nice haze then go back over it w/2000 after that use some compound and then wax should be like brand new here is me and my boy doing it to his s2000 light
its some were in the middle cant remember were
Old Sep 7, 2008 | 03:07 PM
G_whip's Avatar
as far as inside you gotta bake that **** son just look up black house procedures that should help you and then just follow the same steps
Freeman186
Sep 6, 2023 10:07 AM
cmesidewayz
Sep 29, 2015 09:28 PM
NJ6MT
Sep 10, 2015 08:40 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
