California Duster?
Old May 20, 2004 | 10:30 AM
703g35's Avatar
California Duster?
Has anyone used one of these? i saw one of commercials and it seems like it would work, but im not sure if it would scratch my car or not.
Old May 20, 2004 | 02:40 PM
BigRon's Avatar
Re: California Duster?
They work great! I've used them (the same one, actually) for years without ever getting scratches from them.
The key is to shake it out and remove any large debris that would scratch the paint. Of course, you don't have to do this unless you use it on a car that should be washed instead of just dusted.
Definately worth the $10 or $20 that it cost back then. I've had the same one for about 7 years, but I need to replace it because I've abused it a little much by using it to dust what should have been cleaned. But it worked, and still does.
<<<EDIT>>>
Forgot to add, I seem to recall it streaking at first because of whatever the duster is coated with. A word of advice. Use it on several dusty cars first... ...anything dusty will work... ...you just want all of the strands to get a little coated with dust and then it won't ever streak on your paint again. It actually works better once it gets dusty. Just shake excess off and keep going.
Future G35C Owner... ...Never too soon to think about modifications!!
Old May 20, 2004 | 11:34 PM
dyenboy's Avatar
Registered
there's a post about 20 threads down on the same topic..
https://g35driver.com/forums/showfla...t=1#Post258047
Gonna close this thread
GGG Member Signup
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
g.spot
May 9, 2016 10:54 PM
wow600rr
Sep 28, 2015 11:50 AM
corynooooo
Sep 26, 2015 10:54 AM
jbmw002
Sep 10, 2015 12:54 AM
