Rusty Chip Advice
Old Oct 19, 2008 | 04:46 PM
Castle's Avatar
Rusty Chip Advice
I read Picus' post on chip repair but I still have a few more questions. Because it is a sticky most replies will be thanks.
I recently purchased a 06 Coupe that is Diamond Graphite Metallic and it has a 1/10 of an inch chip in the paint on the fender and it has rust in it. I attached a picture with a ball point pen pointing to give reference. What is the best way to clean off the rust? If I need to sand, how should I do this so I can still use touch-up paint? It looks to me around the larger chip that the rust faded into the paint what does that mean?
I think I will need to use a primer because there was rust (that I hopefully removed). Can I spray primer into a cap and use the toothpick method to apply? Also how can I be sure that the primer does not rise up the edge of the chip and show through in the end, or do I even need to worry about that?
After I apply the touch-up paint and wet sand it smooth using 2000-3000 grit do I need to buff it smooth before I clear it? Also what kind of clear coat should I use? Just regular auto krylon clear? I am assuming after i clear I need to wet sand again right?
Please be detailed. And thank for any help.
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
