Applying Klasse
Old May 29, 2004 | 04:27 PM
rvernon's Avatar
Applying Klasse
Couple of questions: Can you apply it in the sun? Is it OK/advisable to use an orbital hand polisher for application and removal? Do you need to put the sealant glaze on right after or can you do it later ie a week later? Any hints or tips for the best results?
Thanks
Old May 29, 2004 | 06:31 PM
lllee's Avatar
Re: Applying Klasse
Klasse goes on well with an orbital buffer. Aside from the better polishing action, it spreads the AIO thinner for easier removal.
Old May 29, 2004 | 09:50 PM
GR8TG35's Avatar
Re: Applying Klasse
Best if you do it in the shade, it will make your life much easier.....it allows the product to dry at a slower rate, and not allow it to evaporate so fast....
Definitely follow up with the sealant glaze, and if you have the time, do a top coat of P21s or S100 carnuaba wax....it will put the finishing touch on your wax job....
I have done the Klasse route back in April, and my car is not garaged.......I usually wash my car at least once or twice a week, and follow up with detail spray after each wash....
Now that I've gone about 6 weeks into the waxing, I noticed some of the swirl marks re-appearing, and the finish is slightly lost its ability to shed water.....
I will try this system once more and see if it will last any longer....if not I think the next shot will be the Zaino route.....
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Jun 1, 2004 | 09:03 PM
IQ9's Avatar
IQ9
Re: Applying Klasse
You can also remove the AIO while it is still semi wet. The product works no matter where you apply it=sun or shade. You don't have to use the sealant but it does make the AIO last longer. If you like to wax you car once a month then you won't need the sealant. Some of us like to cover all the bases just in case we don't have time to wax as often as we like.
03.5 Sedan/B.Sil/Prem/Wntr/Aero/Tint/Rims/Hotchkis Sways--WHERE ARE OUR PARTS!
69 Chevelle Hard Top BB/4.11's/Posi
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
b2autodesigns
Accessories-Vendor
84
Jun 20, 2017 04:38 AM
yosip1115
Aug 26, 2015 10:46 AM
Spartan268
Aug 20, 2015 09:14 PM
Detailed Image
Aug 7, 2015 02:10 PM
