What clay and lube you using?
Old Feb 21, 2009 | 05:00 PM
lekker_droom's Avatar
Just trying to get an idea of what clay and lube to get next.
Been using Meguiar's Mild clay bar and Meguiar's Quik Detailer for lube.
What do most of you use? Clay Magic, Meguiar's, Chemical Guys?
Also, with Clay Magic Medium bar, is any polishing needed after using it or is it still pretty mild?
Old Feb 21, 2009 | 06:33 PM
xXHotelCrazyXx's Avatar
Best ive used!
Old Feb 21, 2009 | 07:17 PM
solopresident's Avatar
teamsolo.net im-integline
i use meguiars and love it! tried mothers didn't like it as much. it left clay on the paint.
Old Feb 21, 2009 | 07:20 PM
PAIXAO's Avatar
I've tried both and have had good results with both. For some reason the SHO paint liked the Mother's better and the G35 paint liked the Meguiar's. Probably due to the age of the paint.
Old Feb 21, 2009 | 07:26 PM
Didnt use enough lube?
Old Feb 21, 2009 | 07:33 PM
no used a lot. I always use a ton of quick detailer. who knows.
Old Feb 21, 2009 | 07:43 PM
Garnet Canuck's Avatar
Traveling Administrator
ClayMagic fine grade with Poorboys Spray & Wipe as the lube.
Old Feb 21, 2009 | 08:53 PM
TheIvoryG's Avatar
Onr
Old Feb 21, 2009 | 10:00 PM
Originally Posted by TheIvoryG
Onr
What about it?
I use this to wash and as a lube, but I also spray Quik Detailer on while claying.
Old Feb 21, 2009 | 10:54 PM
Yea thats weird, ive never had that problem. Maybe your paint just had a lot of contaminants embedded in it
Old Feb 22, 2009 | 02:02 AM
this could be true
Old Feb 22, 2009 | 02:23 AM
Lucky-G's Avatar
Meguiars fine grade clay bar and Meguiars Final Inspection as the lube.
I tried my buddies Wolfgang's claybar and lube and...wow. Just wow....
Old Feb 22, 2009 | 09:11 PM
Detailed Image's Avatar
+1 on Poorboy's Spray & Wipe as clay bar lube. Also Chemical Guys Synthetic Quick Detailer works well too. I like using S&W because it has cleaners in it which helps remove some of the contamination easier.
With any medium grade bar, chances are you're going to encounter some micro-marring in your paint, which will require some polishing to remove.
Hope this helps.
George
Old Feb 22, 2009 | 09:42 PM
Hope this helps.
George
Very much so, thank you.
Old Feb 22, 2009 | 09:47 PM
GLuXuRy's Avatar
chemical guys light clay with chemical guys pro detailer
for bad times chemical guys med clay
