Mildew smell coming from Vents--QUICK FIX!
Old Mar 27, 2009 | 01:10 AM
bigc's Avatar
Wings Nation
15 mins is a bit much. i just turn mine off 2-3 mins before arriving (if I'm using the AC which is almost never here) then just open up the vent. all the ducts & vents are still cold from the AC so you shouldn't see the temp shoot up too much in just a minute or 3
Old Mar 27, 2009 | 12:41 PM
GR8TG35's Avatar
This will help solve your problems in some situations as well.....
Z1products
Old Mar 28, 2009 | 02:48 AM
Grevving6's Avatar
Smile
Originally Posted by visibiliti
omg you bring drinks inside your G!?!? the only food or beverage that ever sees it into the inside of my G is a water bottle!
The first year i was careful not to take drinks in the car because i purchased it for $27,000 and then when i saw the blue book price on it ..It is worth $17,000 ...1 year depreciation of $10k after that i got over it! ..Its a fun car to drive, I just dont baby it as much as i used to.
Old Mar 28, 2009 | 02:57 AM
Grevving6's Avatar
Originally Posted by Dranom
if it smell theres def something wrong with it
also if anyone changes the filter and still has the smell try cleaning the evaporator core. Someone told me mildew also builds up in there.
If you use your AC turn it off 15 mins before arriving to your destination. helps dry the moisture on the core
I tried another way to get rid of the smell now its 95% gone...I left my car in the garage for an hour with windows and sunroof closed. HEATER on 90 degrees at full blast!After the hour was up, I went back to the garage and opened the doors, It stunk really bad. I sprayed a full can of Lysol into all the vents took about 5 minutes to empty the bottle...This helped alot! ..Left it running for another 20 minutes and the smell was gone!
Old Mar 28, 2009 | 04:42 AM
Dranom's Avatar
DAMN!
have you tried replacing the filter?
common guys its just $30 bucks!
Old Mar 28, 2009 | 05:04 PM
Grevving6's Avatar
DAMN!
Filter is 3 months old. About 3,500 miles since installed...The problem that i found was mildew in the vents as well not just a smell from the filter(FOUND BY A dealer tech), he told me to spray it down and it worked!!
TreeFiddy
Aug 10, 2015 06:50 PM
MsFitFern
Aug 9, 2015 02:58 PM
chinee
Aug 8, 2015 10:11 AM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
