Need advice with ScratchX/Scratch Doctor vs. polisher.
Old Apr 25, 2009 | 02:23 PM
johnnyzee's Avatar
Hey guys,
I got an 08 G sedan in white.
The car had a $hitload of rust speckles and contaminants on the paint. So a claybar was needed.
Normally I'd have a detailer do this but my buddy convinced me he's done it before and wanted to do it for me so we did it one day at work. We claybarred it, changing the clay every other panel/door. Car looked great, applied some spray wax and off I went.
Then in the sun the other day, I noticed a hell of a lot of little scratches all over the body, nothing deep, but thousands of swirls and scratches nonetheless. Having a white car they are barely noticeable, but I know they're there. I'm not sure if these are all from the clay, but I haven't noticed them before. Maybe the paint is very clean now and they're more noticeable.
Car's never been polished before.
Question is: Is it safe to use ScratchX all over the car vs. giving it to a professional detailer (Polisher with a machine)? My concern is, I don't want to remove too much clearcoat and I'm wondering if ScratchX is safer, and less clearcoat removal than a pro with a polisher?
Thanks guys, any input helps
EDIT: After some research, scratchX is the final step for deeper scratches. I'd need multiple polishes before any of that, looks like too much of an effort going around 2-3 times by hand with different cut polishes. I might just leave this to the pro.
Old Apr 28, 2009 | 11:41 PM
4DGS's Avatar
Find that guy on here is username is Nikku I believe. He's a Toronto local and will come to your house and detail if need be. The work that I've seen has looked amazing.
Old Apr 29, 2009 | 07:23 AM
35bills's Avatar
Post up some pics of your car....it would help to see how bad the condition of the paint is.
Send a PM to Picus, he is the one to give the best advice to you.
ScratchX is ok for a quick fix up but to use it for the entire car....I would stick to proper methods of using a dedicated polish via random orbital polisher.
Either way, you will not remove very much of the clear coat. Its very miniscule.
If your coming out to the detailing meet in May, you will see what can be done to your car.
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
