Tire Dressing Stains
Old Aug 13, 2009 | 03:17 PM
jeh1110's Avatar
Hello all. I recently cleaned up the car (wash, clay, glaze, sealant, wax). However, I made a mistake with the tire dressing (it's water-based). I didn't wipe off the excess and now it has stained - thankfully only in one area. I tried to use a degreaser, paint cleaner, clay, etc. with no success. I guess I will have to invest in a buffer - just wanted to get some opinions. What do you guys think? Here is a pic of the car and a closeup of the brown stains (not sure if you will be able to see them, but they are there!!!).
Attached Thumbnails Tire Dressing Stains-gigi01.jpg   Tire Dressing Stains-stains.jpg
Old Aug 13, 2009 | 03:30 PM
DetailDan's Avatar
Exactly what dressing did you use?
Old Aug 13, 2009 | 03:46 PM
jeh1110's Avatar
Bold n Bright by Poorboy's World. I think the stuff looks great - I just forgot to wipe it off. One other thing I need to mention is that I had a new exhaust installed. Do you think the heat from the exhaust had something to do with it?
Old Aug 13, 2009 | 04:38 PM
Holmes35's Avatar
stain
There are def some tire dressings that stain...if you have a light colored car like white it will leave brown spots or yellow spots...last week i was at my buddys shop and a customer came in with these stains on all four wheel wells...my friend who owns the shop tried denying that it was the dressing but i am sure thats what it was.....it is a MUST to wipe the dressing in and not leave excess dripping from your tires bc this CAN and WILL happen if you are not careful
good luck getting it out man!
Old Aug 13, 2009 | 09:26 PM
Darkstar752's Avatar
An over the counter polish should get that out by hand. Use Meg's Ultimate Compound followed by a lighter polish like swirlx.
Old Aug 14, 2009 | 02:03 PM
campoly's Avatar
I have the same problem as jeh1110. I bought my G35 used used a few days ago and the dealer cleaned it up and applied the dressing in an attempt to make it purdy' upon delievery. I fear the compound. I've always heard horror stories about "compound" and that it should only be used as a last resort. Is Meg's Ultimate Compound safe for clear coat?
Old Aug 14, 2009 | 08:31 PM
Yea, I think that's something like Turtle Wax Rubbing Compound that isn't paint safe. Ultimate compound is definitely paint safe, but you should follow it up with something like swirlx. Try swirlx first.
Old Aug 15, 2009 | 05:40 AM
TOGWT's Avatar
Use a safe solvent - 3M Adhesive and Wax Remover, and then apply wax / sealant to protect the paint surface
Old Aug 15, 2009 | 09:19 AM
Detailed Image's Avatar
Bold 'n Bright is a water based dressing that shouldn't be hard to remove from your paint if you have a coating of protection on there. A solvent as TOGWT mentioned or a very light abrasive should remove the marks no problem. I'd venture to guess even something as light as Meg's ScratchX would do the trick. Reprotect your paint after using either method.
Next time, after applying Bold 'n Bright, go over it with a towel to buff any excess dressing off. If you like a wetter look, you're better off applying multiple thin coats rather than 1 thick coat.
Let us know if it comes off.
George
Old Aug 16, 2009 | 07:07 AM
campoly's Avatar
George
I tried the scratch X yesterday and it didn't phase the little brown spots. It looks like its deep into the paint. I'll try the Meg's Ultimate Compound today.
Old Aug 16, 2009 | 08:21 AM
How are you applying it and working it?
Old Aug 16, 2009 | 10:57 AM
jlin615's Avatar
I had those brown stains before. I think it's a mixture of brake dust, dirt, and dressing. I took out the stains with couple applications of turtlewax's polishing compound (green label container), then finish it off with detailing polish.
Old Aug 16, 2009 | 08:54 PM
campoly's Avatar
I dab it on and leave it for a few minutes and then rub the hell out of it.
ScratchX is great stuff but it ain't doing it on this one. There is actually a TSB concerning this problem but it doesn't give a solution...just warns about it.
Old Aug 17, 2009 | 01:42 PM
Start rubbing immediately after you apply it.
Old Aug 17, 2009 | 04:21 PM
jeh1110's Avatar
I used Turtle Wax's Polishing Compound (green label) today and unfortunately had no success. I'll try 3M Adhesive and Wax Remover next when I find it. Like campoly said earlier, the stains seem pretty deep.
