Urgent! White Sealant All over my Car!!!
Old Sep 22, 2009 | 04:09 PM
Wannabe6MT's Avatar
-MN G Crew-
Today i ran to Target, and these fvcking piece of **** lazy *** construction workers that are taking forever to make a freaking road were spraying cement sealer on the new cement WITH the wind!!! and the direction my car was!
Now i have little white dots COVERING my car! Wth can i do to get this **** off?!!?!?!?! I tried rubbing it with my finger nail so it comes off, but the problem is its ALL over!
I am in Fargo and i dont have all my detail stuff but i'll gladly go buy whatever i need to get this stuff off! What can i do? HELP!
Old Sep 22, 2009 | 04:13 PM
Jeff92se's Avatar
Red Card Crew
If quick detailer or something doesn't get it off easy, then I'd say you're going to have to use a clay bar. It's the most non-abrasive method I could come up with.
Old Sep 22, 2009 | 04:15 PM
Jeff92se's Avatar
Red Card Crew
Wait bug and tar remover might work.
Old Sep 22, 2009 | 04:16 PM
Wannabe6MT's Avatar
-MN G Crew-
I'm gonna go right now and buy all the crap.
Old Sep 22, 2009 | 04:23 PM
Locksmith's Avatar
Dang that sux janik, good luck getting it all off your car man.
Old Sep 22, 2009 | 05:52 PM
Blue Dream's Avatar
I drove ttrank's car solo
So you took your car to school and this happens? That flat out sux!!!
I'd post in the "Ask a detailer" thread, I bet George has an answer for you. Have you tried the Bug and Tar, might give Goof Off or rubbing alcohol a try if that doesn't work.
Keep us posted!!
Old Sep 22, 2009 | 06:05 PM
Wannabe6MT's Avatar
-MN G Crew-
Tried bug and tar. Didn't work.
I finally just bit the bullet and did the one thing i never thought i'd do.
*gulp*
Took my car to a car wash..... Dons car wash that is... i was just FREAKING the **** out watching my car from behind the glass. Literally just biting my ****ing nails. (no exaggeration either, i do not like car washs)
They pulled it around and wiped it off (went to the nicest car wash in town. I did the basic wash and it was still $13) and it looked good. Pulled out and YES! Most of the **** was blasted off leaving a dot here and there that i fingernailed off. Windows were still covered but i'll get that when i get out of class.
My wheels were also lightly scratched which i flipped the hell out over. Went to the Oreillys and got some mothers mag and aluminum polish. Tried it on a wheel, success.. Thank god. Flew back to school and now im here in class. I'll be campin out in the parking lot afterwards polishing my wheels and getting the last white marks off, but idc. My car is my life and i was seriously ****ting a brick earlier...
I'm just happy i dont have to spend the night in the DIY car wash with a clay bar. Just simply dont have time for that. lots of homework to do.
Old Sep 22, 2009 | 07:55 PM
Detailed Image's Avatar
Using a clay bar should help you safely and effectively remove most of the rest of the spots. Sounds like it's under control though.
Old Sep 22, 2009 | 11:47 PM
Wannabe6MT's Avatar
-MN G Crew-
Yea, after using the dreaded car wash. Ick.
I still have spots on my windows that arent coming off. Ideas?
Old Sep 23, 2009 | 12:51 AM
Darkstar752's Avatar
Spots or raised specks? Glass is MUCH harder than paint, you should be able to safely take it off with a plastic razor.
Old Sep 23, 2009 | 01:42 AM
Wannabe6MT's Avatar
-MN G Crew-
I'll give it a shot tomorrow.
Old Sep 23, 2009 | 09:51 AM
Yep, this is what I typically use, sometimes even a real razor if needed. Lubricate the surface and try to get it as parallel to the glass as possible.
Good advice Darkstar
Old Sep 23, 2009 | 12:25 PM
nghiars's Avatar
yep... i usually use wd40 to lube it up.
Old Sep 26, 2009 | 02:06 AM
Envious Eric's Avatar
lots of glass cleaner and a razor blade will work wonders and make things go by pretty fast.
Karnicle
Jul 23, 2015 05:08 AM
Tylerttn
Jul 13, 2015 04:26 PM
