What Wheel Cleaner do you use?
Old Oct 21, 2009 | 10:12 AM
  #31
YellowTail's Avatar
Originally Posted by Envious Eric
all that means is that you had some severely neglected wheels! Try out some meguiars wheel brightener next time! seriously aggressive stuff for when you need it most!
will that work on stained wheels? i just bought my car and after the purchase, noticed that my wheels looked like they had severe dark "water spots on them" i've tried and tried and tried to clean them but it seems like its set in the paint (i have the 19" oem wheels on my coupe)....so i'm supposed to sand them?
ive tried posting this to another thread about this and have had no response...
Old Oct 21, 2009 | 10:22 AM
  #32
07_Gcoupe's Avatar
Originally Posted by mabaty
Absolutely, works really well to remove little tar specks, etc... I would not clay bar un-coated wheels though unless I had to in order to remove contamination.
Alright... These are my rims... they are somewhat stained by sumthing.. if i clay them do you think itll come off? and also what are the posibilities of the claybay messing up ur rims or no they cant?
Old Oct 21, 2009 | 06:41 PM
  #33
Envious Eric's Avatar
polish is going to work better than claying if stained...
Old Oct 31, 2009 | 01:00 PM
  #34
hg35x's Avatar
WD-40 - I have used WD-40 on friends wheels with baked on brake dust with great results. Do not spray it on, because you might get it on the brakes. Spray it liberally on a cloth, put it on the baked dust, let it sit for at least a couple of minutes, and with a little help with a cloth, it will simply disolve, It works great. Brake dust is a pet peave of mine. I see cars with great wheels and the fronts look black because of the dust. I don't let mine get to the point of baking on the dust. You can put a wheel wax on after they are clean.
Old Oct 31, 2009 | 01:23 PM
  #35
SkylineGTR2789's Avatar
scrub and bubbles.
lol jk.
Old Nov 2, 2009 | 05:03 PM
  #36
dmaculate's Avatar
I am nearly in the same position as the OP. I bought my car used and the oem 19s have brake dust that is caked onto the rims. I've left p21s on there for hours, adding more product every 30 minutes and it did nothing. It doesn't even make a dent. I think it needs a porter cable or something because I have no idea what to use.
I guess I could try a clay bar -- do you need to polish the wheels afterward, like when you clay the car?
Old Nov 2, 2009 | 10:28 PM
  #37
Cabad85's Avatar
If normal cleaning doesn't work try this after washing the wheel with P21S and/or car soap. Use a clay lube/QD as lubricant and clay bar the entire wheel ensuring there is plenty of lubricant, wash/rinse and dry wheel, then follow up with a chemical(non-abrasive) polish like Optimum Poli-Seal or Klasse AIO by hand and remove excess polish. This is what I would do, if that doesn't work, then it might need to be refinished. Good Luck.
Old Nov 3, 2009 | 12:02 AM
  #38
umair's Avatar
Originally Posted by YellowTail
the mr clean magic eraser for wheels. it even took out brake pits.
REALLY???
doesnt that take off layers...?
Old Nov 3, 2009 | 11:54 AM
  #39
hg35x's Avatar
Wd-40 -
Old Nov 3, 2009 | 12:25 PM
  #40
jaysizzlecity2's Avatar
WD 40 oh no this is getting out of hand.....
Old Nov 3, 2009 | 01:18 PM
  #41
I would stick with the nxt all metal polysh, its the best I ever used.
Old Nov 3, 2009 | 02:27 PM
  #42
Darkstar752's Avatar
Metal polish is for metal, not clear coated wheels.
Old Nov 3, 2009 | 05:04 PM
  #43
CreativeDesignZ's Avatar
^ lol alot of people using that on painted finishes...I like poor boys wheel sealant, u put it on once every few months, and u can literally just rinse the brake dust off your rims, hell when it rains my rims get clean. Same with the paint on my car. Zaino FTW!
Old Nov 3, 2009 | 05:15 PM
  #44
Lol........
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
Frostbite91
Aug 12, 2015 05:16 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Tylerttn
Jul 16, 2015 10:33 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
