G35 headlight mess up...help?!?
Old Oct 9, 2009 | 08:35 PM
njg35sedan's Avatar
Unhappy G35 headlight mess up...help?!?
so i have a silver g35 sedan i blackened out the headlights and grille a month ago. i didnt like how amateur the job looked so i re did them today. i also installed 6k hid's on the low beams 8k on the high and got blue bulbs on my fogs and turn signal. after i opened it up i fixed up the inside but my dumb friend took carberator cleaner and used it on the inside of the headlight lens cover. now it wont come out i tried everything..any ideas? or should i just buy a new one...cant seem to find just the cover tho i have to buy the whole thing...
Old Oct 9, 2009 | 08:45 PM
thescreensavers's Avatar
Mr.202?
Edit: Holy crap I read it completely wrong haha. Yea some PlastX or polish/compound will take it out.
Good Luck
Old Oct 9, 2009 | 08:48 PM
JIle342's Avatar
PlastX
Old Oct 9, 2009 | 08:50 PM
F5TG35's Avatar
PlastX FTMFW!!!!
Old Oct 10, 2009 | 02:25 AM
NFSP G35's Avatar
? = 2B || !2B
PlastX will prob do it, but if not get the 3M headlight restore kit that has the drill attachments, just search the forum, I'm sure you can find it.
Old Oct 10, 2009 | 02:27 AM
da mayor's Avatar
and dont let your friend do it
Old Oct 10, 2009 | 02:37 AM
NFSP G35's Avatar
? = 2B || !2B
^ +10,000
You're car doesn't have a carburetor, so the next time someone tries to use carburetor cleaner on it, shoot them.
Old Oct 10, 2009 | 01:53 PM
6MTFTW's Avatar
The inside of the headlight has some sort of film/coating on it. You're not going to get it completely clean, EVER. I used all kinds of chemicals/polish/PlastX, nothing worked. There's no going back.
Old Oct 10, 2009 | 02:00 PM
NFSP G35's Avatar
? = 2B || !2B
^I don't think so. I've seen headlights that were frosted and pitted and everything else brought back. They had to be sanded down a lot though. Still, they came out looking new.
To say "there's no going back" is a bit far I think. Can't hurt to try.
Old Oct 10, 2009 | 02:02 PM
6MTFTW's Avatar
Yes, those were all flaws on the OUTSIDE. However, like I mentioned, there is a film/coating on the INSIDE, which is where the OP's is messed up.
You can try....
Old Oct 10, 2009 | 02:34 PM
njg35sedan's Avatar
ok so i tried it the rubbing compound i tried sanding it i even bought the macguires one with the drill attachment. none of it worked. now i just gave it to him and hes tryin everything he can find from bleach to windex lol. i found a guy in manhatten who has two damaged healights for my car but the cover look brand new. im gonna bake them open them up and just use that cover instead. my car is in peices outside. but atleast my grille and headlights look amazing...minus the messed up cover. lol pix wen im done. =]
Old Oct 10, 2009 | 02:37 PM
NFSP G35's Avatar
? = 2B || !2B
I know, I cought the bit about the film/coating. I'm guessing the coating on the inside is probably some kind of UV protectant, IDK. But my point is, if the plastX doesn't work then he can sand it down from the inside, that would completely eliminate any film on the inside, then sand with a higher grit, even higher grit, cutting polish, etc... In other words, if you completely refinish the inside of the lens in the same way you would badly frosted/tarnished/pitted outside, a film/coating won't matter.
--- edit (didn't see the previous post)
How much did you sand the inside? What grit? etc
Old Oct 10, 2009 | 02:39 PM
njg35sedan's Avatar
You can try....
lol no we tried cleaning the inside and it didnt work at all
Old Oct 10, 2009 | 03:05 PM
njg35sedan's Avatar
i used 120 grit 200 grit an 600 grit. none of it worked. i even had the turtle wax restoration kit which has a rubbing compound and a lubricant in it with small pads of sandpaper in it and that didnt work either. it looks like its just all fogged up
Old Oct 10, 2009 | 03:13 PM
NFSP G35's Avatar
? = 2B || !2B
Ok... 120 was way to low to start and 600 wasn't nearly high enough to finish with. Do a quick search on the forum for restroing headlights or something like that, there's a really good thread that shows how. I still think they can be saved.
BTW, what year is your G?
