Using Meguiar's Scratch Remover w/ the PC 7424 Buffer???
Old Oct 29, 2009 | 10:16 AM
ChrisG35Driver's Avatar
Is this a bad idea? I am trying to get rid of those fine swirls that you can only see in the right light.
Old Oct 29, 2009 | 02:28 PM
trunks333's Avatar
Try Meguiar's Ultimate Compound. They sell it everywhere for $8.
I used it with a 7424, orange pad, and it removed 99% of fine swirls.
Old Oct 29, 2009 | 04:26 PM
Just out of curiosity, do you use the 4.5" or the 6.5" pad. I bought the 6.5" Meguiar's pad before I heard that the 4.5" was better. I am just wondering if it is even a waste of time using a 6.5" pad and I need to just eat the cost of the pads and switch to a 4.5".
Old Oct 29, 2009 | 06:01 PM
trunks333's Avatar
i used the 6.5" pad.
4" is good for tight areas.
Old Oct 29, 2009 | 06:04 PM
Jeff92se's Avatar
Red Card Crew
Meguires products meant for hand applications don't last long enough when it's on the orbital or rotary.
Old Oct 30, 2009 | 02:30 AM
NAMEL355's Avatar
Most people use UC with a DA. I've gotten good results with a DA.
Old Oct 30, 2009 | 10:16 AM
Waht is UC and DA?
Old Oct 30, 2009 | 11:37 AM
thescreensavers's Avatar
Mr.202?
Incorrect...
Most if not all Meguires consumer line polishes/compounds can be used on a DA or by hand. Simple way to find out is to look at instructions on the back of the bottle for what it can be used with. If it lists DA then yes you can use it with your DA. But for rotary use I would say no, since it does not list that it can be used with one on the back of the bottle.
UC= Ultimate compound
DA = Dual Action Polisher
OP, Scratch X 2.0 is 8/10 on the aggressiveness chart I would maybe try SwirlX which is a 5/10 and see if that takes out the swirls you need.
Old Oct 30, 2009 | 12:16 PM
ttrank's Avatar
Grocery getter
^+1
As long as you use the right compound/pad setup you should see results.
Old Oct 30, 2009 | 07:32 PM
Detailed Image's Avatar
Here's a great write up on using Meguiar's M105 and M205 with a Porter Cable for professional quality results.
If you have any questions on anything let me know.
ulmguy84
Aug 5, 2008 01:44 PM
Detailed Image
Jan 16, 2008 12:33 PM
blancmax
Jul 28, 2006 12:00 PM
AsianBoiAnh
Aug 31, 2004 08:58 PM
