Tore a chunk off pad, still good to use?
Old May 10, 2010 | 01:17 PM
9600baud's Avatar
I stupidly buffed a sharp corner on a taillight and got the pad torn, theres like 2 chunks missing.
Is it still safe to use this pad or will it cause scratches?
I'd post a picture but the forums dont seem to have that function working right now...
Thanks!
Old May 10, 2010 | 06:19 PM
Detailed Image's Avatar
Unfortunately a torn pad can potentially create imperfections when your using it. I'd recommend picking up a pad to replace it.
Old May 10, 2010 | 07:33 PM
Darkstar752's Avatar
Yep, I would still save the pad though. I've done jobs like a repair on a rim that I knew would destroy the pad, I wish I would have had a nice worn pad instead of tearing up a newer one.
Old May 11, 2010 | 09:31 AM
9600baud's Avatar
Thanks for the replies and good point on saving it for oddball jobs.
Old May 13, 2010 | 11:53 AM
Yep, wheels, exhaust tips, the nasty painted under parts of the car, under the hood... there are some solid uses for damaged pads, just better off getting new ones for the main part of your paint though.
Old May 20, 2010 | 07:55 PM
never gone's Avatar
Realistically you will be fine. I've taken chunks out here and there and have NEVER had an issue. I'm assuming the chunks you speak of are more towards the sides of the pad? If so it's really no big deal. If they were huge gouges out of the center then sure, replace them.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
Frostbite91
Aug 20, 2015 07:20 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
