using quick guard
Old Nov 20, 2004 | 08:18 PM
yonimation's Avatar
using quick guard
i used the quick guard kit to wash my car today, so first i water down my car then i spray the wash, then spray again and while water is still in the car spray the quick, it says to use the microfiber clother to mix in the chemicals, when im mixin the chemicals theres still water and makes my cloth really really wet, is this how you suppost to do it?
Old Nov 21, 2004 | 01:51 PM
roneski's Avatar
Devil's Advocate
Re: using quick guard
You talking about Crystalguard quick? If so then yeah that's basically how you do it. Spray a little onto the wet car then wipe with the cloth. Then you can buff it out or wash the car again.
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-- Abraham Lincoln
Old Dec 15, 2004 | 12:36 PM
SLiM003's Avatar
i wouldn't wash the car again after applying crystal guard quick. Washing it again will remove the CGQ. You can rinse it again, then dry it to shine. What i usually do is dry the car and then get a spray bottle with water and do it panel by panel. Spray water on one panel and follow up with a CGQ. Spread the chemicals with a damp microfiber cloth and follow up with a dry one. Make sure not to wash the car for atleast 3-4 days curing period time or you will just remove it. good luck.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Jcruzg35
Sep 26, 2015 04:47 PM
mattdg35
Sep 14, 2015 11:28 AM
