Headlight pitting
Old Jul 1, 2011 | 05:03 PM
zoop425's Avatar
Headlight pitting
I just had my headlight done by 180 customs and they look awesome but the lens on the outside appears to have some pitting (more noticeable now on a black background) Its not haze, just like areas where it looks not shiny and a bit bubbly what is they key to getting rid of this? polish? I don't want to wet sand!
Old Jul 8, 2011 | 02:47 PM
zoop425's Avatar
bump?
Old Jul 8, 2011 | 02:57 PM
prinny's Avatar
Wetsand it. You can always polish it afterwards and it'll look just fine.. either that or you can try polishing it first to see if that'll work, but Idk... either or.
Old Jul 8, 2011 | 03:23 PM
zoop425's Avatar
what should I do 2000 then 3000 then polish with a buffer? What polish should I use
Old Jul 8, 2011 | 04:22 PM
prinny's Avatar
If it's not that bad then 3000 should be fine. Just make sure that they're completely smooth after you've sanded them.
For polishing.. PlastiX usually does a good job. If that doesn't then you might need something more aggressive.. like maybe Meguiars M105 and then finish off with PlastiX.
If you're going to do this by hand then it's going to take ALOT of rubbing.
Old Jul 8, 2011 | 05:26 PM
Stryde's Avatar
+1...your arm might actually fall off.
Old Jul 8, 2011 | 06:42 PM
zoop425's Avatar
im going to use a buffer
Old Jul 8, 2011 | 08:54 PM
prinny's Avatar
Perfect. Hope it works out haha
Old Jul 12, 2011 | 01:24 AM
marhew's Avatar
i also suggest you all these things friend.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
