Need some help removing Scuff mark on bumper.
I just grazed the side of a parking garage yesterday and now have HUGE white scuff marks on my left side of my bumper.I own a 2007 g35 sedan. What chemical or compound do you guys recommend to remove the white paint off and fix most of the scratches. Will try to post a pic later. Thanks for the help in advance
Try Meguair's scratch X. You can pick it up at any auto parts store or wal mart. If that does not work you may need to compound to remove it. Scratch X has worked well for me in the past with paint transfer.
Will you be doing this by hand only? Try some Meguiar's Ultimate Compund with a yellow foam applicator. If you are going to be removing this by hand you'll need to put some passion into it. Work small sections at a time and check your results as you move along. Once you have removed the scuff don't forget to apply a light coat of wax.
This is good. I have this.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
