brake dust cleaners
Old May 7, 2012 | 01:51 AM
fatOKOLE's Avatar
brake dust cleaners
What do you use to clean the brake dust off your rims? Will a certain house hold cleaner do the trick?
Old May 7, 2012 | 02:00 AM
thescreensavers's Avatar
Mr.202?
You can use Purple Power or Simply Green
But I find Megauirs Hot Rims All Wheel Cleaner does an amazing job. Just make sure to rinse well and dont let it sit too long.
Old May 8, 2012 | 11:53 AM
Envious Eric's Avatar
sonax full effect wheel cleaner - spray on, let dwell, slight agitation needed for heavier build up, rinse off, dry, DONE
safest and best wheel cleaner I have used. I used to use P21s gel, but it left me reaching for acid all the time. Now I use sonax and the acid hardly comes out!
with any cleaner, dont use it in the sun or on hot wheels after a long drive!
Old May 8, 2012 | 12:06 PM
BlackG35Shine's Avatar
Use simple green! That works amazing on brake dust!
Old May 8, 2012 | 01:03 PM
bluedevils95's Avatar
Simple green and i also use meguires wheel cleaner too.
Old May 8, 2012 | 04:08 PM
Jairen's Avatar
Sonax, as mentioned.
Old Aug 18, 2012 | 01:56 PM
SuperTrooper699's Avatar
what about painted wheels? mine are painted gloss black? will that hurt the paint or clear coat?
Old Aug 20, 2012 | 01:57 AM
no, you are fine with painted wheels
non-cleared/aluminum wheels you have to be careful with
Old Sep 15, 2012 | 01:33 PM
gary c's Avatar
First of all you never want to clean any wheels if they're hot, let em cool before spraying anything on them. You can clean most wheels with what manufactures offer but I'd do one at a time and rinse throughly. Wheels (Volks) like mine that I've removed the clear coat and had polished I clean with detail spray (cold) and apply Mothers metal cleaner with microfiber towels....Gary
Old Sep 27, 2012 | 03:09 AM
cindykmason's Avatar
If you want to ensure that a brake dust cleaner is effective is to use the correct type and use it thoroughly.
Visit us at cars auto auction
Old Sep 27, 2012 | 10:36 PM
Detailed Image's Avatar
SONAX Wheel Cleaner Full Effect is safe on almost every wheel finish including painted wheels. As mentioned above just make sure the wheels and brake pads are cool and this pH neutral cleaner will impress you quickly!
Greg @ DI
Old Sep 28, 2012 | 05:19 PM
V's G's Avatar
I use Sonax too. - makes life a whole lot easier.
Old Oct 1, 2012 | 12:22 PM
achillesg's Avatar
Is this safe to use on the stock wheels of a 2003.5 sedan (6 spokes)? The website says:
Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
And I think mine are aluminum?
Old Oct 1, 2012 | 04:28 PM
V's G's Avatar
I have stock wheels and it works fine. I have the 5 spoke.
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
