best product for removing that faded yellow haz on headlights?
Old Aug 5, 2012 | 12:27 PM
G-Ryder03coupe's Avatar
I've tried numerous products but it'll last for a few days till it rains again then it looks like crap again. I've never sanded them . Need help here
Old Aug 10, 2012 | 05:14 PM
BlackG35Shine's Avatar
Check out my headlight restoration! it is my full restoration I did and should help you with any questions.
Old Aug 10, 2012 | 08:38 PM
broker99's Avatar
how bad are they? I cleaned these RX-8 headlights with 3 inch pads with Meguiar's 105 and 205.
other side corrected
once they are corrected you will need to coat them with some type of protection. Any kind of plastic cleaner will work if they just have a light haze. Optimum Opti-Coat is a good choice for permant protection.
Old Aug 14, 2012 | 08:18 PM
onthe3rdday's Avatar
I did mine earlier today with Meguiars plastic X to remove the hazing. I only have "After" shots but my lights look amazing. I have light pitting on the surface of the lights so in the future I may sand it out.
Old Aug 14, 2012 | 09:17 PM
Damn those Rx8 light came out great mine aren't that bad but I want them to look like new again. I just bought the turtle wax headlight restoration kit well see if that works I'm doing it tomorrow I'll take before and after pics if not them I'll get the 3m kit I've heard its really good
Old Aug 14, 2012 | 09:50 PM
05 sedan's Avatar
use sylvania headlight restoration it comes with a clear coat you put on after you finish polishing them and they dont turn yellow again
Old Aug 15, 2012 | 03:15 AM
Mr. Brett's Avatar
Your headlights re-haze because the UV protectant has been removed, and the plastic is exposed and oxidizes. You need to put some sort of sealant with UV inhibitors on the plastic to keep it from yellowing over again.
Old Aug 15, 2012 | 10:14 AM
superman22x's Avatar
For mine, I wet sanded with 2000 grit, then used a Meguiar's polish, and then finished with a Meguiar's glaze. I did the same thing on my old 96 motorcycle taillights which were hazed much worse. Both shine and are very clear now. These were just some products sitting on my friend's shelf at the time, but they worked well.
Now, I got lucky and all my having was on the outside of the housing. This is not always the case though.
Old Aug 15, 2012 | 10:06 PM
Old Aug 15, 2012 | 10:08 PM
Size:  113.9 KBafter. Didn't even have sand it. Just used the compound stuff it brought let it haze and used a buffer on it and then just the sealant. Came out good
Old Aug 23, 2012 | 11:06 PM
BluIDvl's Avatar
All i used on my 03 was 3M rubbing compound....rough towel to rub & a micrfiber to buff clean!!! You can see the crap come off on to the towel, plus i always wax or polish my head&tail lights to keep them protected!
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
G35fromPA
Interior
21
Sep 20, 2015 08:58 AM
FRUG35
Aug 25, 2015 09:40 PM
Mick_L
Aug 25, 2015 04:27 PM
06G35Kurtis
Aug 23, 2015 12:24 AM
