Debadge Fail Help!
Old Jun 25, 2013 | 10:23 PM
xFALCONS7x's Avatar
Debadge Fail Help!
Okay so I Looked through numerous debadge fail threads and none were as bad as mine...so i need some suggestions on where to go from here.
there is an outline of the Mt. fuji that is impossible to get out and very noticeable
Ive tried goo gone, medium grade clay bar, and aggressive polish with my pc 7424xp and its not getting this outline out
Ive debadged the G35 and INFINITI in the past and was just getting tired of the Mt Fuji when I waxed...
please help! If it wont come out by tomorrow than i will take it to a professional to get it wet sanded.
btw I know there is a new debadge thread everyday but Ive never seen one go this wrong Thanks...
Old Jun 26, 2013 | 12:13 AM
xFALCONS7x's Avatar
pics
Old Jun 26, 2013 | 12:26 AM
hurleyguys's Avatar
hmm hard to tell from pic. is the outline etching in the clear? or is is all the way through the paint to the primer/base coat? if it is just etching then it will take a wet sand and polishing. if its the other it will need to be repainted.
Old Jun 26, 2013 | 12:35 AM
qbcsvt's Avatar
A wet sand isnt hard to do . Get a flexible sanding block and start wet sanding with high grit. 2000+ if you feel comfortable go lower. Then all you have to do is buff, polish and wax.
Its not too hard, unfortunately with that said - black is the hardest color to deal with.
GL
Old Jun 26, 2013 | 01:43 AM
xFALCONS7x's Avatar
thanks for your replys I will try wetsanding it in the morning... worst case scenario i will just powdercoat the emblem gloss black and put it back on... Ive been thinking about getting a AMS v1 trunk anyway so this may just make that decision easier
Old Jun 26, 2013 | 08:25 AM
ReStylin's Avatar
No really. Wet Sanding is NOT hard...
Spray bottle with water + a drop or two of soap.
Get some 2000grit paper, and a Bondo block sander.
Soak paper for about 10 mins then put it int he block sander
Lightly sand the area, do not put pressure on it. You arnt sanding wood. You are sanding MICRON's of the clear coat away. Nothing more.
After the 2000 grit, go to a cutting compound. Start with a medium cutting compound.
I would put your 7424xp to the side for this.. Buy a rotary.... a Makita 9227C is best bang for buck, and you WILL use it again.
Use a Wool pad. 7-8 inch, Tape your edes, keep your speed down to 1000-1500rpm, again, minimum pressure, a wool pad with compound on high speed or high pressure will damage faster then you can say "Oh shiat"
After compound, use polish, then wax. Should be good as new.
Something that size shouldnt take more then 15 minutes. That includes tapeing it up etc etc.
Even if you are buying a AMS trunk... do this... Fix this, if you screw up, fix that! Eventually you will get the hang of it and your car will love it, your friends and family will love you for it.
Your RO will do it... but it will take days....
Old Jun 26, 2013 | 08:44 AM
LoSt180's Avatar
Try some wax remover. That looks like wax build up from years of waxing your car.
Old Jun 26, 2013 | 10:48 AM
gary c's Avatar
From the pic that looks like more than just a shadow, can you feel the outline of the Fuji emblem? Did you saturate the shadow several times with a rag filled with Googone? All to often members rebadge using super glue, hope this isn't the case which would require the lid being repainted. I had a shadow on my trunklid, nothing in my garage would remove it until I used a high speed buffer and fine compound followed by several coats of quality wax.
Gary
Old Jun 28, 2013 | 03:04 AM
DieuNay's Avatar
i feel your pain
Old Jun 28, 2013 | 10:15 AM
ErikTaylor's Avatar
Gary
I had shadow on my lid too. I'll give that a try and see how it comes out.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
sullivan72
Sep 22, 2015 11:39 PM
SupermanGPS
Sep 19, 2015 01:42 PM
