2005 G Coupe Dash Panel Deterioration
Old Sep 6, 2020 | 01:42 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
2005 G Coupe owned since new, second car, 47K miles, warm garage kept, very well cared for inside and out. Noticed haze developing on rubbery part of dash panel, especially after car had sat 5 months over winter. Used Sonax dashboard cleaner and followed with 303 Aerospace dressing. The haze reappeared so I reached out to Detailed Image and they recommended Gtechniq Tri-Clean followed with Gtechniq Matte Dash. Seemed to work better, but the haze is reappearing. When car is out and sun heats up the dash panel, the haze goes away and is replaced by the shine of the product, but then returns after car has sat in garage for a couple weeks. Reached out to local detail shop and they advised they were familiar with the dash material and they just were not made to last and breakdown. They suggested to not use any cleaners and just keep reapplying some sort of silicon based dressing. Has anyone else had to deal with this issue and if so, what did you do? A new dash panel itself is expensive and probably very expensive to have installed. Any advice is appreciated. Thank you.
Old Sep 15, 2020 | 04:27 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Got any pics of the haze? I assume by the "rubbery part" you are referring to the section that faces the passengers? My coupe is also garaged and stored winters. I think one spring I did have some sort of film after taking it out of storage, but as far as I know I don't have a haze. I've been more concerned about it cracking so I started using 303 protectant as well, and also purchased a sunshade for when it's not in the garage. Maybe this is outdated information, but I head read (many) years ago that silicone-based dressings (e.g. Armor All) were actually bad for dashboards.
As far as replacing the dash cover, I doubt you could even find a new one in stock anywhere.
Old Sep 16, 2020 | 06:17 AM
DRG35R's Avatar
20 Year Member
no pics unfortunately as I just dressed it recently. yes, the dash pad that faces passengers. it is like a film that you can wipe away by just rubbing your fingers on it. once dressed, it look like new again. understand the car is 15 years old, but it still looks like new inside and out and want to keep it that way. there are no cracks anywhere in dash as it has been very well maintained. have found some new dash pads in some dealers inventory, but they are expensive and even more so to install. will just keep re-applying the Gtechniq C6 Matte Dash or 303 and just try to keep it looking nice as I do not think there are any other options other than a new dash. could have an auto re-upholstery shop do a new dash in alcantara if the situation becomes worse.
Old Sep 16, 2020 | 02:59 PM
20 Year Member
I'm surprised to see that you were able to find new dash pads. Which dealers had them and what was the cost?
Old Sep 17, 2020 | 05:38 AM
DRG35R's Avatar
20 Year Member
there are several. just google infiniti parts and look up dash panel/pad or instrument panel. infinitipartsdeal.com has them listed in black for $1,333.13, which is pretty good.
most are $2,300+ on sites like parts.infinitiusa,com. several sites show discontinued.
Old Sep 18, 2020 | 10:12 PM
bambiG35's Avatar
G35 Coupe
Unhappy New Dash 2006 G Cpe-Need Lid Cluster Also Unable to Locate
I just had my dashboard replaced, 2006 G35 Coupe replaced, w/70K miles, due to it was cracking and had a sticky feel almost like glue. The new dashboard was $1,900 for just the dash, not including installation, which was not that bad, I think around $400 labor, from my mechanic, but does not include the piece where the clock sits called a lid cluster top, Part #68257-AC701, which is actually part of the dash in the middle. Can't find that part no where! It is part of the dash, but actually seperate. .Hmm...Dash was split there as well, so now I have a new dashboard w/a split where the clock sits, I'm soo upset, as I've been renovating it it to be almost new again and ran into this. You and I both might be able to use the complete Dash Finisher, Part #68247AC70D to complete the dash, but then again could not find that part either. Clearlake Infiniti online out of TX, has the best online prices for the dashboards I found. The mechanic that put mine in, ordered in from our local Infiniti dealer in Louisiana. You might want to call the dealer & give them your VIN #, so they can give you the Part # for your dashboard... BUT YOU WILL "NEVER" find the piece of the dash, which does not come w/the dash, where the clock sits, Part #'s above...This chic would give anything to locate either of these parts. Wish you luck with your dash if you replace it, it looks great, except the part above when the clock sits.
Old Sep 18, 2020 | 10:18 PM
bambiG35's Avatar
G35 Coupe
I just ordered or try to order the Lid Cluster Top or even the Dash Finisher to complete my new dashboard I purchased. It shows all available, transaction went thru, stated they had it in stock, but then they credited back my cc account, due to NOT HAVING IN STOCK, at Infinitipartsdeal.com, believe me I have called & been online for a day looking for just the Lid Cluster Top or even the Complete Dash Finisher, NO ONE HAS IT IN STOCK. As for as the dashboard, I found them in stock at Infiniti Clearlake in Tx, or your local dealer can order the dash but you will need the Lid Cluster Top, which seems to be invisible, LOL...
Old Sep 19, 2020 | 05:55 AM
DRG35R's Avatar
20 Year Member
fortunately my dash panel/pad is not cracked at all. the part of the dash panel/pad that has a sort of rubbery feel to it develops a tacky haze on it if not consistently dressed with protectant like I mentioned earlier. guess things could be worse and I am thankful it is not cracked anywhere. will just stay on top of adding protectant more regularly. just noticed this started last year after the car had sat in garage over winter like it always has. after it is dressed with something like Gtechniq C6 Matte Dash, it looks brand new again. will not use anymore cleaners on that area. if I replaced it, would only need that panel as the areas around the clock and instrument cluster are made of a different and harder plastic material. by the time I would need a new dash panel/pad replaced, they will all be gone from any remaining leftover dealer stock. here is the part # I found, F8200-EH31A. plus it does not seem cost effective to replace with that same material if it will just deteriorate again. have seen people have the dash re-upholstered with black alcantara and it looks great. that may be a better option down the road if things get worse. for now, just keep up the protectants. hope you can find your parts. I always get the part # first and then just Google it to see if there are any dealers with it in stock.
Old Jul 8, 2021 | 09:32 AM
CFE4130's Avatar
Have you tried any of the pull-a-part yards in Louisiana? They have a few G35s
thinkricky
Interior
Jan 15, 2018 07:36 AM
beniscooler850
Interior
Sep 19, 2012 04:34 PM
louisdarke
Florida G Club
Oct 21, 2008 04:09 PM
