How can i detail this paint? And is it possible to make glossy?
Old Sep 20, 2021 | 09:07 PM
Kris4655's Avatar
G35 coupe
So i have this 03 g35 coupe, with a Ivory Pearl Clearcoat, its sorta matte but it shines, how can i detail it, and can it be made glossy? Thanks!
Old Sep 21, 2021 | 06:17 AM
Scorpi0's Avatar
Im sure your local car wash can polish some shine back into it.
Old Sep 24, 2021 | 11:09 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you want to do it yourself you're going to need a dual orbital polisher and some product. I personally like these items
-Porter Cable 7424XP but don't use the foam pad that it comes with, throw that thing away and get a hook/loop (velcro) backer pad like the next item.
-Astro Pneumatic 4607, it's a 5" backer pad which is the size that works with the next item
-Chemical Guys hex logic pads, they're 5.5", they are color coded for the various grits, here is a snippet of the chart so you can decide which ones you need. You can skip every other pad if you want. If you try to skip two grit the smoother pad doesn't have enough to remove the marks from the previous. If you only skip one pad grit you can still remove the marks from the previous. I only use orange and grey, the 3 on the right side (blue, red, black) are if you are trying to get back to showroom quality and my car is a daily driver that isn't garaged so it's pretty pointless to put that kind of finish on the paint.
Next you will need some polishing compount, I like Optimum Car Care stuff, their aggressive polishing compound is called,
-Optimum 20604 Hyper COMPOUND
I use it on the orange pad, follow it up with.
-Optimum 20574 Hyper POLISH on the white pad.
You're sure to get quite a bit of advice on products to use, there's a LOT of good stuff on the market.
Old Sep 24, 2021 | 03:56 PM
Kris4655's Avatar
G35 coupe
Much appreciated 😊😊 will give it a shot
Old Sep 24, 2021 | 05:58 PM
jbarnett250's Avatar
There is a guy called junkman3000 on youtube that does lots of good videos about paint correction for beginners. his videos will show you how to use all the stuff cleric recommended. i got totally into that a couple years ago. it's not hard to put a mirror finish back into an old car if the damage is all in the clear coat like swirls. It takes a long time if you want to do it really well though.
Old Sep 27, 2021 | 03:13 AM
Kris4655's Avatar
G35 coupe
Anything for the g, appreciate the tips!
TEEEJAE
Jun 3, 2010 04:45 PM
Brian-g35
Jun 20, 2005 11:08 PM
Type_R_Boy_251
Sep 2, 2004 06:30 PM
