Porter-Cable 7424 Buffer: Ever Used It?
Old Apr 4, 2005 | 09:21 PM
fotodad's Avatar
I'm seriously considering getting an electric buffer for applying polishes and waxes. It seems the industry standard is the Porter-Cable 7424. Has anyone used a power buffer, specifically the Porter-Cable? If so, what are your thoughts? Does it do a better job than hand polishing and waxing?
Old Apr 4, 2005 | 10:21 PM
GEE35FX's Avatar
fotodad....I know a few of the guys on the regional Canadian forum use the 7424 and also the PC7336, and from all reports I have heard they are very pleased with them. I am presently looking for a PC polisher myself because of what I have heard and read.
Wayne
Old Apr 5, 2005 | 07:10 PM
Punchit's Avatar
I'm a detailer and i use the Porter and I'm very pleased with the results. I don't know if its that much better than others but it definitely works well. The difference between doing it by hand or using a Porter is you get a more even distribution of products and pressure. Its difficult to apply constant and even pressure with your hand. If you get the Porter you will still have to go back and do quite a few spots by hand. Good luck and let us know how it works out for you.
Old Apr 5, 2005 | 08:04 PM
hksjza70's Avatar
I use a 7424, couldn't find a safer way to knock down swirls!
Obviously you'll need a velcro backing pad and a good supply of foam pads, but you won't regret it.
Old Apr 7, 2005 | 12:11 PM
G35_4_Me's Avatar
For more information on the PC 7424, checkout the forums/review sections of autopia.org.
Oh, and be warned that once you start visiting autopia, you may find yourself spending entire weekends detailing your car.
Old Apr 7, 2005 | 07:15 PM
Diesel1's Avatar
Moderator
This is my machine of choice! I hope to put it to good use this Saturday! The Cyclo random orbit counter rotating dual heads!
Attached Thumbnails Porter-Cable 7424 Buffer: Ever Used It?-cyclo.jpg
Detailed Image
Jun 23, 2009 07:54 AM
Detailed Image
Oct 6, 2008 12:00 PM
Detailed Image
Aug 30, 2008 08:11 PM
Detailed Image
Nov 19, 2007 11:21 AM
