McGuires Scratch X Swirl and Scratch remover
Old Apr 8, 2005 | 12:54 AM
g35crzy's Avatar
Hi guys, I was wondering when do you put the stuff (McGuires Scratch X swirl and Scratch Remover) on and how long do you leave it on before wiping it off the car. Thanks!
Old Apr 9, 2005 | 01:58 PM
cyphr's Avatar
I'm not sure if this is the correct procedure but i removed my scratch x immediately after application. It seemed to work pretty well. Another product to check out is 3M Swirl Remover part #39009 (for dark cars). I've heard a lot of people rave about it on my350.
Old Apr 29, 2005 | 12:48 PM
P_Diddy's Avatar
I just found a long scuff mark on my right front quarter panel. I'm not sure if I slid across the car while installing my plenum spacer or someone else did it. The abrasion marks look kinda deep. I hope I can get it out!
Are the Maguiars and 3M products mentioned above ok to apply over a couple coats of Zaino?
Old Apr 29, 2005 | 01:34 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It doesn't work by leaving it on.
You rub out the scatch (I use a microfiber pad).
Then clean it up.
I then follow up with Meg. pro polish to bring the gloss back up.
Clean it up then wax as normal.
Old Apr 29, 2005 | 04:00 PM
Punchit's Avatar
Yea you can remove it right after you apply it. Leaving it on any longer won't help, it may actually make the removal process a little harder and flakey.
Old Apr 29, 2005 | 04:30 PM
BlackonBlackG35's Avatar
Yeah you can use ScratchX but it will definitely remove any product you have on there. So you will have to re-wax the area.
Since nobody in this thread knows how to spell it, Meguiars.
Old May 3, 2005 | 02:49 PM
P_Diddy's Avatar
I used the Meguiars ScratchX on Sunday after I washed the car. After a few coats, the scuff is gone!! I didn't apply any more Zaino because immediately after I washed, there was pollen on the windows. So I'll have to wait....
Old May 4, 2005 | 10:50 PM
G35Luver's Avatar
I've swirls all over my black car (stupid dealer washed my car >:[ ),
can I apply it all over the car with porter 7424 as if I were waxing?
Old May 20, 2005 | 01:26 PM
Basheer's Avatar
Call the Cops
thats not fair
bring it back to them and demand a deatailing job
Old May 20, 2005 | 02:51 PM
jimcambell's Avatar
ScratchX is NOT made to be used with machine application. It's a by-hand product only.
If you want to use a 7424, depending on how bad the swirls are, you should use
Meguiars Dual Action Cleaner Polish (#83 I think). It's in their professional line. For any information you can check out www.megauirsonline.com forums.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
dcsbh1
Oct 1, 2015 03:15 PM
vQFamily
Sep 30, 2015 01:17 PM
