Clean Engine Bay
Old May 11, 2005 | 08:46 PM
HipHopPro's Avatar
Clean Engine Bay
Holla,
How do you guys/gals keep your engine bay clean? that's if you keep it clean.
Old May 13, 2005 | 12:17 PM
Gumba35's Avatar
I'm actually going to clean mine this weekend. I'm planning on blowing all the loose dirt out with an air compressor then wiping it down with a damp towel. If someone has any better ideas I would like to know.
Old May 14, 2005 | 08:15 AM
jonw's Avatar
With todays engines, You can just blow the loose dirt away, then spray the engine with Autoglym engine cleaner. Spray it liberly over everything nd let it set for a fe minutes. Now aggitate the worse spots with a stiff brush and rince with water. You may need to repeat thie process afew time until tis been thourly clean.
Now while the engine is still wet spray Autoglym vinyl and rubber care over the entire engine.
Close the hood and you are done.
Autoglym Engine cleaner
Autoglym Vinyl and Rubber care
Detailing the engine article
Attached are before and after pictures of a Lexu SC400 we did.
Attached Thumbnails Clean Engine Bay-picture-073.jpg   Clean Engine Bay-picture-080.jpg
Old May 14, 2005 | 08:20 AM
snowman's Avatar
There are a couple of different products on this site...they all work really well but of course you need to be careful where you are spraying them.
http://www.gunk.com/Degreasers.asp
Old May 14, 2005 | 12:33 PM
S-Tuned's Avatar
gtr proto test driver
black magic engine cleaner works good
Old May 16, 2005 | 10:12 PM
RPMZ's Avatar
I use a very mild degreaser on muddy spots, and gently scrub any other dirt thats let off with a damp towel and then wipe everything down with a dry towel afterwards. Tire shine wipes work very well for hoses and such.
Old May 16, 2005 | 10:27 PM
mizzoutiger's Avatar
http://www.autopia-carcare.com/inf-engine.html
Old May 16, 2005 | 11:33 PM
hksjza70's Avatar
those autoglym pictures look fantastic - but I'd be scared to hose the engine bay down - way too much water in all the electronics
zoop425
Mar 29, 2016 05:51 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
