how to clean microfiber towel?
Old Jun 9, 2005 | 10:15 PM
blazinZ's Avatar
Question how to clean microfiber towel?
how do you clean your microfiber towels.... is there a process or do you just buy new ones after a use.
Old Jun 9, 2005 | 10:21 PM
G's Up's Avatar
throw them in the washer and use them over and over
Old Jun 9, 2005 | 10:51 PM
blazinZ's Avatar
any special way wash and dry?
Old Jun 9, 2005 | 11:37 PM
Slicktide's Avatar
Read somewhere wash normal with detergent but don't use fabric softner.
Old Jun 10, 2005 | 02:38 AM
blazinZ's Avatar
thanx... good info
Old Jun 10, 2005 | 08:03 AM
jimcambell's Avatar
Wash them ONLY with other microfibers. If you wash with other "regular" cotton towels, they will pick up all the lint.
Old Jun 10, 2005 | 08:29 AM
wjfm1's Avatar
Use liquid detergent only and air dry in the dryer.
Old Jun 10, 2005 | 09:50 AM
Blackjack's Avatar
Exactly! By themselves, "normal" detergent, no fabric softener, no dryer sheet.
Old Jun 10, 2005 | 01:47 PM
blazinZ's Avatar
thanx fellas
Old Jun 10, 2005 | 05:59 PM
maxpower's Avatar
MAINTAINING MICROFIBER
I’ve read a lot of tips on how to clean and care for microfiber. It’s really very simple.
The best general purpose cleaner is a liquid detergent. It’s better to use too little than too much. Liquid is recommended over powder because some powders do not completely dissolve and the granules will lodge in the toweling.
Wash in cold water only. Warm water can be tolerated, but hot water cannot. Polyester and polyamide both shrink in hot water. If you wash in hot water the fibers will shrink and the towel will not perform as intended.
Do not use fabric softeners of any kind. The softener will become lodged in the microfiber reducing its ability to absorb water, clean and pick up dirt. In short, you’ll have a soft towel that’s useless.
Do not dry above medium heat. Treat microfiber towels the same as you would your delicate clothing. Drying with high heat is worse that washing in hot water.
Just recently, a cleaning solution was developed specifically for cleaning microfiber towels. I tested a product called Micro-Restore Detergent that claims to effectively remove dirt without using the bleaches and softeners commonly found in laundry detergents. After cleaning several loads of dirty towels, I made the switch. My towels now seem to last longer and don’t get matted down.
all you ever wanted to know about MF towels:
http://www.autopia-carcare.com/inf-microfiber.html
Old Jun 11, 2005 | 10:59 AM
Vic's Avatar
Vic
wait, I thought that we are suppose to wash the towel with warm water... not cold..
Old Jun 11, 2005 | 11:29 AM
Blackjack's Avatar
Cold is preferred, Luke warm is fine... just not hot water.
Old Jun 11, 2005 | 06:19 PM
bigjorge3g's Avatar
I agree w/ what MaxPower posted however I'm not completely sold on the "Micro-restore" detergent, I've used Pinnicle and couldn't see a difference. Just don't use fabric softener.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
Detailed Image
Sep 17, 2015 07:38 AM
