Zaino rubbing off color?
Ok, I guess this is good news. I wiped off Z2 last night with a white towel and on all the metal panels nothing showed up. Howeverrrr... I found out where the blue color is coming from: The bottom plastic parts on both sides (you know, under the door, that bottom plastic area between where you would have the splash guards installed). No orange peel on paint - I really checked. Now I wonder why blue is coming off there...
Are you talking about your side skirts? I had the same thing happen on my side skirts. The only area it happened to was that absolute end of the side skirt. That flat surface right behind the front wheel. It looked as if the clear coat was never sprayed on that edge. But the rest of my side skirt was fine. If you are able to rub the paint off the entire side skirt, then i'd be concerned. Take a picture just so we can verify.
But now that you're saying it happened to you too, what's going on? Anyone else have this issue? Do we need to talk to Infiniti about this?
