Exciting new instructions for Crystal Guard applic
Old Jul 4, 2003 | 08:27 PM
Ca_Kid's Avatar
Exciting new instructions for Crystal Guard Quick application
Introduction:
This posting has been reviewed by the folks at Crystal Guard who tested these instructions on an available vehicle. They found increased brilliance as measured by their gloss meter. I am a skeptic at heart, but found that Crystal Guard was not only extremely easy and quick to apply, but produced an outstanding shine. While these instructions I devised will involve a little extra effort on your part, I know that you will be especially pleased with the end results this extra effort produces. The instructions below assume that you have thoroughly washed and dried your vehicle.
Application of water with Crystal Guard Quick. The ratio of water with the Crystal Guard application can be critical. You really don’t need to use a lot of water. I recommend that you consider purchasing a small 12 oz. spray bottle that produces a fine mist. Rite Aid stores appear to be everywhere, and they have a small spray bottle (Model 1152) that is ideal for this situation. But any small bottle that produces a fine spray would be satisfactory.
By using this spray bottle, you are not diluting the effectiveness of the Crystal Guard as would be the case by leaving your auto covered with water from the garden hose. Use your spray bottle to moisten a small area, then spray the Crystal Guard over the same area. You want to work with small areas at a time, and not allow the Crystal Guard water mixture to dry out. I would suggest that you use two Micro Fiber cloths, one to spread out the water/Crystal Guard, and then follow up with a dry Micro Fiber cloth about 30 seconds later. Remember, this is NOT wax, and hard rubbing is not required nor recommended.
What kind of water to use? Again, these instructions are designed to produce an outstanding shine on your vehicle pride and joy. It is my recommendation that you use carbon filtered water in the spray bottle. Such water can be obtained at any major grocery store. Stay away from most bottled water where they claim it comes from mountain streams. While it may taste very good, it probably contains small mineral deposits which we are attempting to avoid. Brita also makes small pitchers containing carbon filters to filter your home tap water for placement in your refrigerator. Why am I recommending that you go to this extent to produce an exceptional shine on your vehicle? To verify the importance of this recommendation, try this. Leave some of your garden hose water on your vehicle for several hours, and then observe what is left behind when the droplets have evaporated. Little rings of mineral. This is the stuff you remove when you carefully chamois your vehicle after a wash. I am just suggesting that you start with super clean water to achieve superior results.
A very satisfied Crystal Guard user. CA_Kid
03G35c/C_Blue/Willow/5AT/Premium/Splash/Garmin SteetPilot III/V1/SAT/XM/18" PermaStar rims w/NITTOs.
Old Jul 11, 2003 | 05:54 AM
Scoop's Avatar
Re: Exciting new instructions for Crystal Guard applic
Thanks for the info CA_KID I'm about to use CG and appreciate the help
L8r
Scoop
Old Jul 11, 2003 | 09:54 AM
malx's Avatar
Do you recommend I do my best in getting the swirls out of my car before I apply CG?
Thanks - Joey Avino
Old Jul 11, 2003 | 01:09 PM
Gordgee's Avatar
Administrator
If you're fussy about the water you use, you should consider distilled water which is available by the gallon at most pharmacies. You're right about most bottled waters though. Most actualy have a high mineral content than even your tap water. Some even have more minerals added in to improve the taste and for supposed health benefits.
<font color=green>GG</font color=green>
Old Jul 13, 2003 | 11:32 AM
Alkettory's Avatar
Well, I just tried CA_Kid's "Exciting New" method for applying Crystal Guard Quick, and I'm happy to report that it works as advertised. My car looks terrific (sorry, no pics; I don't have a digital camera).
It took somewhere between 1.5 & 2 ounces of CG Quick to do the entire car, including windows & wheels. For water, I used distilled water from Wal-mart (57 cents/gallon).
Since this is the first time I've used CG Quick (my G is is less than 2 weeks old), I can't compare the Exciting New method to the original method of application, but reading about others' experiences on this board, it certainly sound like the new method used a lot less CG Quick than the old method would have.
It'll be interesting to see how the application holds up over time.
James
2003 G35C, 6MT, DG/W
Old Aug 27, 2003 | 06:58 PM
masetodd's Avatar
Jeezus! I thought I was **** about keeping my car clean - but washing it with distilled water!? My hat is off to you guys! An A+ for effort!
G35 6MT/DG/Fully Loaded
Old Aug 27, 2003 | 09:35 PM
juiceman's Avatar
what is the thought to applying CG to a car that has been teflon treated?
Bought CG for the minivan and the car came treated with a teflon based product. Will it do any good or should i wait 6 months?
Have a healthy day!
93 J30t, Black on Black
03.5 G35, Black on Black
Old Oct 26, 2003 | 06:25 PM
lamrnd03's Avatar
Hi Buddy,
Should the first micro fiber cloth be wet or damp? Should I clay bar first? O.K. to put over Teflon application?
Thanks,
Michele
lamrnd03
Old Oct 26, 2003 | 06:46 PM
GeoBau's Avatar
Cactus Hugging Admin
The microfiber that you use to "spread" it should be damp. Spray water and a tad of CG on it, then use it to spread around what you've sprayed on the car. Claybar first, yes, it's always a good idea to get all the contamination off the paint before you do. Also, Dawn it to make sure you get any residual wax, etc. that's been previously applied. As for the Teflon coating, I'm not sure how durable it is, but it doesn't hurt to throw CG on it. All the best,
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
Old Dec 10, 2003 | 07:17 PM
Sloanhaus's Avatar
I bought the entire CG package about 5 months ago. I have since put CG quick on twice...Should I wash my G35 with Dawn if I have the complete CG on it or will this take away the coat that has set in. Thanks
Old Dec 11, 2003 | 12:47 PM
juiceman's Avatar
from what I have read someone said the CG company stated that dawn (original) will remove it all
Might want to confirm with the company
Have a healthy day!
Old Dec 22, 2003 | 12:53 AM
Eurog35's Avatar
ok for this cg quick thing, lets say i dawn wash my car to remove any previous wax, and then dry it and then CG quick my car... and like 2 months later i decided to re CG it, do i need to dawn wash it again and then reapply the CG or can i simply add a new coat to the previous one? please help
Old Dec 22, 2003 | 11:17 PM
GeoBau's Avatar
You can just add a new coat. Might want to claybar, though.
G
Old Dec 29, 2003 | 04:38 PM
gman4gman's Avatar
Nobody uses the CG wash???
I CG'ed my G sedan for the first time this past weekend...I dawned it first and rinsed completely. Then I came back with the CG wash/microfiber panel by panel and rinced again then came the quick/water mix from spraybottle w/ microfiber... I let it sit for a minute and wiped it off...my car looked fantastic!!! Would have taken pics of our clear blue sky reflected from the hood, but my neighbors were out...they already think I'm annal about this car:>) Total time to wash and apply this first time...about 2.5 hours with most of the time spent on that friggin' break dust!!! Love CG...
G35S 6MT!! DIAM GRAPH/ GRAPH BELLS WHISTLES...DEFINETLY WORTH THE WAIT!!!
Old Dec 29, 2003 | 05:13 PM
GeoBau's Avatar
I would, but it's illegal to wash your own car in Vegas now. [img]/w3timages/icons/crazy.gif[/img]
G
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
