Gas spilled on the perforated seat
Old Sep 22, 2005 | 05:36 PM
Gilley's Avatar
What can I do to remove the gas and odor that spilled on the seat from the gas can?
I looked at some Internet boards and they suggest using vinegar and laundry detergent. Is there some other cleaner?
If the leather wasn't perforated, I could have wiped it right up with no problem, but some soaked into the foam. At least it was the back seat of the sedan.
Old Sep 22, 2005 | 05:53 PM
Picus's Avatar
Staff ALUMNI
There are a lot of ways to remove smells, but I think in this case the best bet would be to dilute some white vinegar with some water (3:1 water:vinegar, I would say) then scrub the area down well, and wipe down right after. If the smell comes back, repeat as necassary over the coming week - it shouldn't remain after a few wipedowns.
If that doesn't do it for you (either the smell, or you don't like the idea) try some of this:
http://www.zeocrystal.com/products.html
I use that stuff all the time (the powder) and it really does work. It won't eliminate the actual gas spill, but the smell will be gone.
Old Sep 22, 2005 | 06:13 PM
MikeyMike's Avatar
Rollin On Dubz
Febreze, perhaps?
Old Sep 22, 2005 | 09:24 PM
Gilley's Avatar
Lucky it was the back seat. I took the cushion out and used some soapy water and squished it through the foam and used towels to soak it up. Then repeated it a couple of times. I'm going to leave it out and let it dry a couple of days.
Old Sep 23, 2005 | 08:45 AM
jimcambell's Avatar
You were carrying a gas can in your back seat?
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Hogbone
Sep 28, 2015 06:44 PM
doakley92
Sep 25, 2015 12:58 PM
