Crystal Guard instructions
Old Aug 16, 2003 | 08:12 PM
R1cky's Avatar
I just bought the Crystal Guard wash and quick.
It say on the instructions:
1. Rinse the entire car with water.
2. Spray the CG wash on entire car.
3. Wash the car with microfiber cloth with some water.
4. Now apply CG Quick on entire car while its still wet.
( This is what I have question on. Do u rinse the CG Wash
off with water b4 apply CG Quick? Or do u just apply CG
Quick over CG Wash?)
( Also they said apply the CG Quick while the car is wet, if
car is dry, do u have to rewet it?)
( Does the CG Quick dries quick? Should I work little
section at a time?)
( And after apply on CG Quick and spread with Micronfiber.
Do u have to wait until the CG Quick dry, then rinse with
water?)
( And finally rense and dry. What do u dry it with?
Microfiber cloth? Or any kind of soft cloth?)
Anyone has experience with Crystal Guard please reply. Explain the procedure steps of wash and apply. Thanx in advance...
Old Aug 17, 2003 | 12:49 AM
RamboRami's Avatar
G35driver.com Moderator
Re: Crystal Guard instructions
word of advice.....scrap their instructions, lol
here i will try to find you some good instructions...
by the way, the CG Wash is kinda useless unless you have the PRO kit.
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Aug 17, 2003 | 12:53 AM
RamboRami's Avatar
instruction set #1
instruction set #2 (my own way of CG'ing)
Old Aug 17, 2003 | 01:36 PM
R1cky's Avatar
Thanx for the instructions... I'll try it out today, I'll post the results when I'm finish...
Old Aug 18, 2003 | 07:03 PM
R1cky's Avatar
I washed my G-Coupe yesterday and dry it. Then lightly mist one panel at a time with a bottle of H2O, and then spray CG Quick over it. Spead / wipe with the Microfiber cloth until alomst dry ( there are swirl marks from the CG ). Then mist the whole car with H2O again wipe it down with the same Microfibe cloth ( but I rinse the cloth with H2O ). After I wiped the whole car down, but I still see swirl marks from CG.
How can I get rid of it??? Or do u leave it alone???
Old Aug 19, 2003 | 11:12 AM
RamboRami's Avatar
Is it from the hazing or are the scratches (from previous waxes/washings)?
Another Q, did you apply pressure when "spreading" and "wiping"?
Old Mar 14, 2004 | 04:57 AM
nuttyprof's Avatar
i read the instructions, but dont see how to do your console? do you mean your interior center console? would you take some pix of it? is it all shiny? hehee sounds interesting.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
JWT popcharger + Z-tube
Stillen True Dual Exhaust
6-wire ground kit
Old Mar 16, 2004 | 01:11 PM
RamboRami's Avatar
yeah make sure the area is clean, then just take a damp MF towel and spray some CG-Quick on it, then wipe on all over the silver console, then wipe with a damp MF towel (without any CG on it) then repeat the process 1 or 2 more times.
It does look shinier and i havent had any scratches on mine yet (knock on wood) and its been almost 1 year
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
laksjd84
Jul 24, 2015 05:12 PM
