How to fix??
Old Mar 4, 2006 | 08:13 PM
GThIrtYFiZle's Avatar
How to fix??
So I was parked and when I got back I saw my rear bumper had a nice little scratch on it about an inch or so mayb a bit smaller and deep enough to see the black. My car is IP.. I do have touch up paint,,, how should I do it to get the best results???
Old Mar 6, 2006 | 08:25 AM
GTScott's Avatar
To get the best results, I would suggest filling in the scratch and then using a kit like the Langka (www.langka.com) chemical kit or the Norton wet sanding kit to smooth in the spots. These will basically eliminate the blobs that often appear from the use of touchup paint. I have used the wetsanding kit and had good luck. It works best with solid colors but should be good with your IP as well. The problem with metallics and other strange paints is that the metallic portion settles down and thus the color match is not 100%. There is some language floating around on a means by which to address this. The langka kit uses a chemical (basically paint thinner) to soften up the "blob" of new touchup paint and then let you smooth it down. You should be fine with either kit.
-GT
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
