paint/plastic sheathing I pursuade: do not mix
Old Mar 13, 2006 | 10:01 PM
jayelleseven's Avatar
From: socal--not leavin this place, jus takin over it one venture at a time.
Hey fellas, havent been here in a while n heres my big problem:
I covered my car with a plastic cover (regular plastic sheathing) since I did not have a car cover the day after: 1/ My car was Egged (yes I washed that off) and 2/ there was Hail falling randomly the day after that. I left it for a few hours during the cold day and later that nite for almost the entire night
Now I am left with this:
after rubbing compound and waxing (Meguiars), still visible:
the new wax shine makes it harder 2 see but only at some angles and the worst is on the side:
There is also a purple-ish mark that must have come from the small lettering on the plastic. Im assuming the vapor/moisture trapped in the gaps somehow marked up my paint... And yeah I had no clue plastic sheathing would do this, i know its my stupidity and I should have known.. any help/advice would be awesome, thanks_
Old Mar 13, 2006 | 11:06 PM
absolutg's Avatar
workin...
i'd suggest taking it to a really good detailers. hopefully they can claybar/polish that out...
Old Mar 14, 2006 | 12:04 AM
yeah before that i will have it buffed, if that doesnt work then claybar n polish would be next, i was even told at the meguiars forum to try isoproply alcohol (i also read about vinegar) to release the moisture, wet sanding would be my LAst option =/
Old Mar 16, 2006 | 07:52 AM
GTScott's Avatar
A 50/50 alcohol wipedown will probably not help you much unless you can *feel* the contaminants on the surface.
To me, it looks like it needs to be hit with a G-safe compound, polished, and sealed. It may take a somewhat abrasive compound to tackle that and thus you may need to follow that compound with something a bit lighter. To me, this looks like a perfect candidate for Poorboy's SSR2.5 -> SR1 -> Pro Polish -> EX-P sealant. You will need to play around a bit and see which compound to start with to actually remove the problems and not induce additional marring.
Best of luck!
-GT
Old Mar 25, 2006 | 11:51 AM
Down_Shift's Avatar
Use Nylon Spotter or Acrylic Solvent. I'm not sure if they are off the shelf items though.
A wet sand and a polish combo will probably work too.
brownie
Nov 25, 2015 12:50 AM
Mignav01
Aug 22, 2015 03:12 AM
Phenomenon9
Aug 9, 2015 01:34 AM
joedaddy1
Jul 28, 2015 02:58 PM
