Can I was my car with Cotton instead of Microfiber
Old Sep 4, 2003 | 11:08 PM
DaN_the_MaN's Avatar
Ok guys. I finally got my Zaino kit in the mail and I also recieved my microfiber towels. I ordered 3 microfiber wash mitts and a CA Water Blade from autogeek, but it's gonna take almost another week to get here and I am anxious to start washing my car tonite.
My Question, can I was my car with a 100% Terry Cloth Towel instead or should I wait for the microfiber wash mitts?
I called Pep Boys and they said they didnt sell any microfiber wash mitts. Where else can I get one locally?
Thanks guys
Twilight Blue G35 Coupe 6M/T
Premium - Navi - Aero - Trunk Mat
Old Sep 5, 2003 | 09:07 AM
tkman00's Avatar
Re: Can I was my car with Cotton instead of Microfiber
dan
i would stay away from the waterblade. after i soap up the car and rinse it off, i take off the bulk of the water w/ an absorber. you can readily find those in pep boys. make sure than when you use it, you keep debris off of it. after taking off a bulk of the water, i follow it up w/ a microfiber towel. this process becomes much easier after you zaino. i only use 100% made in the usa cotton towels when it comes to taking the zaino off. after that, everything goes into the washer.
if you insist on using the blade, make sure that it is absolutely clean and that you apply absolutely no pressure. if you are a newb when it comes to detailing (not saying that you are), i would prefer that you stay away from the water blade.
Old Sep 5, 2003 | 12:00 PM
Ok, I will stay away from it. But, you didnt answer my first question. Is it Ok to was my car with a 100% cotton towel than a microfiber wash mitt?
Old Sep 5, 2003 | 02:31 PM
tkman00's Avatar
heh, sorry about that. i suppose if the wash mit is 100% clean, then you should be ok. personally i just use a natural sponge, but then again i don't apply much pressure. the key here is to try your hardest not to use anything to scratch the surface of the car.
ultimately you need to make sure that your mitt/towels don't keep any debris in the between wipes. again personally i would use a sponge, as i can see how a towel can keep loose debris in between it's fibers.
you can also refer to this https://g35driver.com/forums/showfla...&part=all&vc=1
<P ID="edit"><FONT class="small"><EM>Edited by tkman00 on 09/05/03 11:37 AM.</EM></FONT></P>
Old Sep 5, 2003 | 05:01 PM
Shader7's Avatar
All my towels are microfiber. I use four for each wash: one for washing, one for bulk drying (ringing it out periodically), and one for final drying. The last one I keep inside the car for spot touch ups (inside and out).
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
Detailed Image
Jul 21, 2015 08:50 AM
