Need help using detailing spray
Old Apr 9, 2006 | 05:31 PM
harley01's Avatar
I tried using some Sonus detailing spray on my hood, but can't get rid of all the streaks. I tried to reapply some, but it now looks worse. I'm going to have to rewash the hood. It has been about six months into a full Zaino application..could this cause the issue? How much pressure should I apply when buffing?
Old Apr 9, 2006 | 11:24 PM
WRAH's Avatar
WRAH
Sonus detailing spray shouldn't affect Zanio. I would wash again with a mild soap, and rinse really well. Most problems with detail spray are soap residue, oil or dirt.
Old Apr 9, 2006 | 11:26 PM
WRAH's Avatar
WRAH
As to the buffing question, very little when using detail spray. Because it tip. used after washing or dusting pressing too hard could cause paint damage.
Old Apr 10, 2006 | 08:54 AM
Picus's Avatar
Staff ALUMNI
Is it the carnauba spritz you're using? If so, make sure to shake it *very* well as the carnuaba tends to settle. Also, do not use it in below 40F weather, it will definitely streak. One spritz should do half a hood at minimum. Just spray and gently buff off with a mf cloth.
Old Apr 10, 2006 | 01:09 PM
GTScott's Avatar
It sounds to be like you are either not shaking it (good point picus, I have seen this with a LOT of detailers like Poorboy's QD/QW+ and the Sonus) or you are using it on a good that is too warm or in direct sunlight. If you drive off the volatiles too quickly you will be left with streaks. Just about ANY detail spray can do that, carnuba or otherwise.
As for pressure, you need little to none.
-GT
Old Apr 10, 2006 | 07:33 PM
Punchit's Avatar
Great Points Picus and GTscott! I think you guys got the major points. Also make sure you have a clean and dry microfiber cloth for removal.
Old Apr 13, 2006 | 03:16 PM
_jb's Avatar
_jb
Photographer
If you have Zaino on your car, why not use Zaino's Detailing Spray... Z-6 or Z-8... they work great...
Old Apr 13, 2006 | 03:51 PM
GT-Ron's Avatar
Don't they! I just did Z8 on the rear of my car in about 15 minutes during lunch. I'm prepping for a coat of Z2 and then another Z8 spritz tonight.
I've only used Z2 once (2 coats) since I took delivery almost a year ago (2500 miles / garaged). I've just washed with Zaino regularly and then hit it with Z6 or Z8 and it looks freshly waxed. Great protection still, but I feel like I owe it to her to give her the 3-step again.
Dallsinghjr1
Sep 17, 2023 11:25 AM
g.spot
May 9, 2016 10:54 PM
Jeff T
Sep 30, 2015 02:00 PM
