303 aerospace protectant
Old Apr 13, 2006 | 11:36 PM
mng35's Avatar
Hey guys, I was wondering if anyone uses this stuff and for what do you use it.Do you think its good? Thanks
Old Apr 13, 2006 | 11:41 PM
mc2's Avatar
mc2
I use it along with the 303 cleaner on everything in the car. Leather, dash, vinyl. everything that needs to be protected from the sun.
I alternate on the leather with lexol conditioner.
Old Apr 13, 2006 | 11:43 PM
aszatk01's Avatar
^^^exactly the same as mc2
although i dont have the cleaner....
its like an spf 30 for your car
Old Apr 13, 2006 | 11:46 PM
mng35's Avatar
What is the best tire/Wheel combo cleaner?
Old Apr 14, 2006 | 12:19 AM
jinubob81's Avatar
Evil Bastard
simple green or dishwasher fluid. also, use a synthetic polish after you do so, to make it easier to clean later. Also, it does that whole, "WTF so shiny FTW"
Old Apr 15, 2006 | 04:11 AM
s14roller's Avatar
Ive used it also on my cars...works well so far.
Old Apr 15, 2006 | 04:53 AM
Alan's Avatar
if you guys are running aftermarket wheels, dilute the simple green to about 10% that stuff is concentrated enough to damage your wheels.
Old Apr 16, 2006 | 01:18 AM
mercury3545's Avatar
I work at a wakeboarding shop that also sells boats, and we use 303 on every boat we sell. That stuff works awsome.
Old Apr 16, 2006 | 11:20 AM
Picus's Avatar
Staff ALUMNI
Guys - fwiw, if you're using Simple Green, get the automotive stuff. It's much less harsh and needs to be dilluted less, plus it won't dry out/degrade rubber. I've been using Simple Green (heavily dilluted) a long time, and now that I've seen what it can do to rubber first hand I've moved over to the automotive stuff. YMMV.
As for 303 - I have gallons of it. It's been around forever, it works well, it protects, it looks good. Hard to beat.
Old Apr 17, 2006 | 10:47 PM
mng35's Avatar
Thanks, 303 it is then..
Old Apr 18, 2006 | 05:34 PM
Punchit's Avatar
The 303 Aerospace Cleaner is the same exact chemical as the 303 Cleaner and Spot remover and 303 Fabric Cleaner. The prediluted version is the 303 Cleaner and Spot Remover and the concentrated version of the same exact product is the 303 Fabric Cleaner. This can be diluted up to about a 10:1 ratio, which makes 320 ounces of cleaning solution so you probably don't need the gallon version. Its a great cleaner that works extremely well on the entire interior. You can use iit on leather to clean but it has no conditioners.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Detailed Image
Sep 8, 2015 02:42 PM
