Grrrr.wheat leather stained?
Old May 8, 2006 | 05:16 PM
Grace's Avatar
Avoiding potholes
Angry Grrrr.wheat leather stained?
Ok. Someone's got to have a fix for this. Pleasepleaseplease.
Somehow I've stained the outer lip of the seat. I think getting in and out of the car in a series of brown or black leather jackets or skirts did it. I've tried a few leather cleaners that were in the bf's garage. Nothing (and I mean nothing) has helped.
Is there any way to remove the greyish color?
Any suggestions are greatly appreciated.
grace
Old May 8, 2006 | 05:37 PM
Picus's Avatar
Staff ALUMNI
I'd try two things. First the easy one:
Get some woolite (the regular laundry detergent) and mix it 5:1 with water. Spray the area and lightly scrub with a soft brush. This may work, it may not. Perhaps try a slightly strong concentration if it doesn't.
If that doesn't do it I would bite the bullet and buy some Leatherique Pristine clean. It's about the best leather cleaner I've used. I've taken out some serious stains with it. If that doesn't do it you've got me beat. Good luck.
Old May 8, 2006 | 06:07 PM
D87's Avatar
D87
Try the Mr. Clean Magic Eraser, though I would try in an inconspicuous spot first. It worked for me in taking out a lot of stuff.
Old May 8, 2006 | 06:45 PM
Picus's Avatar
Staff ALUMNI
Not a bad idea, be careful with it though - the eraser is essentially sandpaper. Don't use it on anything with a gloss.
Old May 9, 2006 | 10:33 AM
Punchit's Avatar
Just be careful with the eraser, it has stained some surfaces I've used it on around the house, not sure how it is on the seat. I use the Leatherique Prestine Clean with great results and would consider it the premier leather cleaner out there.
Old May 9, 2006 | 12:53 PM
Grace's Avatar
Avoiding potholes
Thank you for the fast responses! I've been so very careful it was frustrating to find the discoloration on the seat this weekend.
I didn't have Woolite but tried my reg detergent (All Free and Pure) in a weak soulution. It seemed to take most of it out. Did you hear the huge sigh of relief coming from California?
I'm going to hunt down the Pristine clean this weekend.
Thanks once again!
grace
Old May 9, 2006 | 01:42 PM
RetardGarage's Avatar
-1 on the "Magic Eraser" - Keep that away from your leather.
+1 on the Leatherique. Best stuff ever.
Old May 9, 2006 | 05:05 PM
Picus's Avatar
Staff ALUMNI
Thanks once again!
grace
Awesome. Glad it worked out!
Old May 9, 2006 | 06:57 PM
D87's Avatar
D87
Hmm.. I used it on my Willow leather and it got the nasty stuff out... You got bad experiences from it on your leather in your G?
Old May 9, 2006 | 07:10 PM
Picus's Avatar
Staff ALUMNI
D87 - if it worked for you that's definitely a good thing. I think some of us guys would be reluctant to use it on leather because it's basically a small block of fine sandpaper, and it tends to dull glossy finishes (for example, use it on a gloss paint wall in your home and you'll notice the paint looks flat afterwards). Since most car leather is actually covered in a thin layer of glossy plastic I would be careful with the eraser and leather, lest you go through the plastic.
Just imo, of course.
Old May 9, 2006 | 11:55 PM
Leather in the G is real thin, and it's dyed.
Easy to go through the dye.
Old May 10, 2006 | 12:25 PM
D87's Avatar
D87
Ah I see. I didn't even think of it as sandpaper. I actually used it like a sponge and "dabbed" rather than "scrubed" to soak up the grime and such.
nissandrifter32
Dec 22, 2015 04:28 PM
NailBomb
Oct 28, 2015 07:53 AM
MrIP35
Oct 25, 2015 11:13 PM
TNRocker
Sep 21, 2015 08:36 AM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
