Another Recall- Looks like we might just blow up
Old Jul 5, 2006 | 11:29 AM
JD_AND_DA_G_RIDE's Avatar
Post Another Recall- Looks like we might just blow up
Selected vehicle: 2003 INFINITI G35 V6 3.5 Liter FI
File Date 12/13/2005
Mfr. Involved NISSAN NORTH AMERICA, INC.
NHTSA Campaign # 05V555000
Mfr. Campaign # R0505 & R0
Component Affected FUEL SYSTEM, GASOLINE
# Vehicles Affected 192659
Defect ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE FUEL FILLER HOSE MAY CRACK AND RESULT IN FUEL LEAKAGE FROM THE HOSE WHILE REFUELING.
Consequence FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.
Corrective Action DEALERS WILL REPLACE THE FUEL FILLER HOSE. RECALL BEGAN ON FEBRUARY 27, 2006, FOR NISSAN OWNERS, AND ON MARCH 13, 2006, FOR INFINITI OWNERS. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Old Jul 6, 2006 | 11:03 AM
BeerViper's Avatar
Where have you been?? I had this recall done in April!
I would be careful though ... hyperlite had it done down in Houston and they have to remove the exhaust to replace the filler hose. They didn't replace the gasket after putting the exhaust back together and he ended up with an annoying loud exhaust system.
For me no exhaust problems but ever since this getting this recall done my fuel gauge does not go all the way to Full ('F') when I fill the tank and then the low fuel light goes on when I have like 5 gallons left. I've had it back twice to get it fixed and each time they changed some flap but it didn't help *annoyed*
Old Jul 6, 2006 | 11:35 AM
I would have them check your fuel sending unit. Mine starting doing this a good while back and the whole unit was failing. The flap is the "known" TSB for that problem but a lot of G's have had fuel pump/sending unit failures.
Old Jul 6, 2006 | 12:11 PM
g35rcr's Avatar
Hey Beerviper its not you ive seen around bedford area in a black coupe with a billet grill is it?
Old Jul 10, 2006 | 12:56 PM
BeerViper's Avatar
Nope not me ... DG coupe with UT grille ... check my sig for a link to pics
Old Jul 10, 2006 | 03:03 PM
Melissa's Avatar
If it wasn't me, then it's someone wanting to be like me!!!
Old Jul 11, 2006 | 10:05 AM
theeggman's Avatar
My car is at Grubbs getting this issue fixed. Make sure if you do bring in your car that you include your wheel lock key. They do need to remove your rear wheel.
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
mattdg35
Sep 14, 2015 11:28 AM
