My alignment saga continues....
Old Mar 28, 2008 | 11:01 AM
  #31
Mad A's Avatar
lol, interesting point of view.
Let's all get into the Toe Bolt business
Old Mar 28, 2008 | 12:40 PM
  #32
TwoK4drSi's Avatar
Dude, don't steal my idea
Old Mar 28, 2008 | 12:45 PM
  #33
Mad A's Avatar
Hey, hey.. you got your territory and I got mine, capish? You don't want to collaborate on this, that's fine. I see your men peddling their bolts on my turf.. we're gonna have problems, and you don't want that.
Old Mar 28, 2008 | 02:26 PM
  #34
TwoK4drSi's Avatar
Do you know who I am? Do you? I am with the Yakuza and if I see you selling your shiet here I will take my ninja sword and start cutting stuff off!
Old Mar 29, 2008 | 02:33 PM
  #35
BeerViper's Avatar
Well I'm about to go install the toe bolts that I got from THMotorsports (got here in 2 days!). The instructions that come with the bolts aren't very detailed so I searched for a DIY and found practically nothing here on driver ... so over to my350 and blam there it was! The thread gives a link to a PDF that shows you just how to do it: http://turboneticsownersclub.com/tur...oltinstall.pdf
Old Mar 29, 2008 | 04:08 PM
  #36
Mad A's Avatar
Sweet. Hope this is enough to solve your camber problem!
Old Mar 30, 2008 | 01:02 PM
  #37
BeerViper's Avatar
My biggest problem in the rear is to toe, I have Stillen adjustable camber arms but the problem is when you bring the camber more positive, the toe goes more negative.
I did the install yesterday based on the links above and it really wasn't bad at all. I picked up a #115 dremel bit and after jacking up the rear allowing the suspension to hang I unbolted the stock toe bolt and used the dremel bit to elongate the hole. I couldn't believe how easily that dremel bit dug through that aluminum!!
While it was still jacked up I did an "eye" adjustment for the rear toe so it looks like the rear tires are facing the fronts. It's amazing how much toe adjustment is available in the rear tires, just by spinning the back of the toe bolt you watch the rear tire turn in and out like it has 4WS
Anyways, always rewarding to do something on your own car and learn a little more about how everything works. I feel confident enough that if I had the equipment to tell me the angles that I could align the rear tires no problem.
The front camber, now that is a different story altogether! -2.5°
Old Mar 31, 2008 | 10:41 AM
  #38
TwoK4drSi's Avatar
You really shouldn't worry about camber. It's toe that kills tires. Camber you can always get 100% out of your tires by swapping them over.
Old Mar 31, 2008 | 02:40 PM
  #39
BeerViper's Avatar
It's just a pain swapping tires over every 5k miles and having to worry about the shop scratching my wheels doing the dismount/remount since they are directional tires.
Alignment specs show a maximum of -1.25° camber in the fronts so I am running twice that. I just have to decide if I want to spend ~$400 for the front a-arms and then worry about rotating less...
Old Mar 31, 2008 | 06:49 PM
  #40
g35rcr's Avatar
that is not true or convenient...
Old Apr 2, 2008 | 12:59 AM
  #41
BeerViper's Avatar
After the toe bolt install this weekend I made it back to Dallas Frame & Alignment today. I request Josh to do the alignment as he was the one that helped me out before.
Ran into a little snag when he tried to adjust the rear camber ... the Stillen camber arms were at their max positive adjustment although there were plenty of threads showing to move it more negative. It appears that when the adjustable camber arms were installed, they were not centered in the threads to allow enough positive adjustment. What this meant was that the camber bar needed to be dismounted, spun out and then reinstalled. In order to get the the camber bolt out, you have to remove the rear sway bar and all the plastic diffusers around it (pain). I just told him to go ahead and do it even though I was considering replacing the sway bars soon.
In the end he got the rear camber at -1.4° with a total toe at +3/16" (very very slight toe in). The front is still sitting at a heavy -2.5° camber with a total toe at +1/8".
I hadn't experienced any severe wear of the front tires with the camber the way it is, Josh explained that was partly due to the toe in compensating for the drastic camber. I will keep an eye on the tire wear over the next 5k miles and see those a-arms are really needed.
THE END!
Old Apr 2, 2008 | 09:27 AM
  #42
firefox's Avatar
It should make the track more interesting.
Old Apr 2, 2008 | 12:07 PM
  #43
TwoK4drSi's Avatar
Well then don't modify your car if you woory about things being convenient and yes toe kill tires more than camber
  #44
TwoK4drSi's Avatar
THE END!
And the town rejoices!
Old Apr 2, 2008 | 01:47 PM
  #45
g35rcr's Avatar
i could have so much fun with that comment but just to inform, i have a 1 inch drop and am currently running a 295x35x18 rear end...so yes i do have some basis for my comment
