Need adjustable end links- chime in with reccomendations
Old May 11, 2009 | 05:44 PM
Mad A's Avatar
Hey guys,
Turns out the popping noise I've been hearing is most likely from my sway bar end link. I need to buy some adjustable ones, anyone have a suggestion?
Old May 11, 2009 | 05:57 PM
waijai's Avatar
i.love.gold
SPL come highly recommended.
http://www.splparts.com/main4/parts/...rs/default.htm
Old May 11, 2009 | 06:00 PM
User 92024's Avatar
Originally Posted by waijai
^^^^+111111
I got popping coming from mine after i put on my Stillen Sways, I thought it was the compression rods but nope, seems like the end links. I have stock rubber bushings that i need to change out too while im at it...
Old May 11, 2009 | 06:07 PM
Mad A's Avatar
https://g35driver.com/forums/brakes-...end-links.html
I see you've been through this Will!
I will probably go with the powergrids from what I've read and seen. Thanks guys!
Old May 11, 2009 | 06:59 PM
jran76's Avatar
I have heard great things about the Powergrids from Z1.
Old May 11, 2009 | 07:32 PM
tonke73's Avatar
+1 on Powergrids from what i hear. BTW. They only make the rear set for the G37 sedan.
Old May 11, 2009 | 08:01 PM
syshs's Avatar
Im using the oem 06 end links with my hotchkis sways, no popping, no nothing. Using the bushings that came with the hotchkis sways.
Old May 11, 2009 | 08:19 PM
waijai's Avatar
i.love.gold
The end links will eventually wear out. Since Adam has quite a bit of track time and has dialed in his suspension for road race, i would imagine his setup to experience more wear and tear than the normal street setup. I've got the Nismo sways and the endlinks eventually wore out after quite a while.
Old May 11, 2009 | 08:30 PM
syshs's Avatar
^ Makes sense.
My car is only street driven, that too w 20k miles only... so ya, I dont need aftermarket end links, yet.
Old May 11, 2009 | 11:44 PM
tonke73's Avatar
Originally Posted by syshs
^ Makes sense.
Was I supposed to connect your end links to your sway bars? Oh Sh****t, I forgot and left them hanging. Just kidding yash!
Old May 11, 2009 | 11:46 PM
syshs's Avatar
^ haha!
Old May 12, 2009 | 01:13 AM
g35man04's Avatar
CLUB MODERATOR
I have the SPL Adjustable end links on my car!! no complaints here Adam
Old May 12, 2009 | 01:33 AM
firefox's Avatar
I have SPL end links as well. On the front, there are two pieces to the spacer. One piece (the conical piece) and the short cylinder looking thing that looks like a thick washer. I used both, and this washer wore out, which lead to a clicking sound. I have since removed this washer and only use the cone spacer. Everything is fine now.
Old May 12, 2009 | 09:30 AM
BlueBOB's Avatar
is there something better about the 06 end links?
Old May 12, 2009 | 10:32 AM
Mad A's Avatar
The 06 and up endlinks are beefier. I already have those, and they finally wore out after about 1500 miles. It's exactly as Will said, due to the track time and road race suspension tuning I now have to get aftermarket parts.
Does anyone other than Z1 carry the powergrids? I am thinking if I'm gonna go aftermarket with the endlinks, might as well go all out. But Z1 is currently out and will get their next shipment next week.
By the way, anyone with pre 06 endlinks can get the 06 end links under warranty, that's what I did last year.
