Turning off slip?
Old May 21, 2009 | 11:07 PM
Mad A's Avatar
short solution, turn off VDC.
Old May 21, 2009 | 11:15 PM
thescreensavers's Avatar
Mr.202?
No no, He wants to get rid of slip, turn on VDC it will make you not slip. :P just had to sorry
Old May 21, 2009 | 11:25 PM
BlueBOB's Avatar
i've wanted a permanent VDC off button as well... can't find one
Old May 21, 2009 | 11:34 PM
StuLax18's Avatar
Think you could reverse it where it was always off and you had to hit the button to turn it on?
Old May 21, 2009 | 11:35 PM
syshs's Avatar
+1
Ignition start. Turn off VDC.
Keep a post-it sign somewhere in ur car where u will see it until it becomes a habit.
Old May 21, 2009 | 11:49 PM
g35man04's Avatar
CLUB MODERATOR
I thought KP Technologies had a module that remember the VDC off...
MOMENT OF TRUTH!!!
http://www.kptechnologies.com/products.php#/4
The traction control module is used to add a memory feature to the traction control switch in your vehicle. The unit automatically stores the ON/OFF state of the switch when the vehicle is shut off and restores the setting when the ignition is turned on. This module remembers the turned off feature everytime you shut the car off.
Old May 21, 2009 | 11:51 PM
TXaaron3232's Avatar
Its the button next to your trunk button.
Old May 21, 2009 | 11:52 PM
tbrillz35's Avatar
Yup, just turn it off every time you get in and turn the car on, don't be lazy
Sit, Seatbelt, VDC OFF, Drive.
Old May 22, 2009 | 12:07 AM
g35man04's Avatar
CLUB MODERATOR
yeah but its the burden of everytime having to do it...for 39.99 you dont ever have to do it again.
Old May 22, 2009 | 12:18 AM
roygrady's Avatar
Yeah good mod for the lazy haha
Old May 22, 2009 | 12:24 AM
Mad A's Avatar
To elaborate:
You don't want the slip light coming on, meaning you don't want traction control kicking in, so you turn VDC off. That takes care of the problem...
mostly.
In reality even when it is turned off, the traction control is not 100% disabled. For most purposes though, this will be fine, you can still brake loose, spin your tires, lose traction, dyno your car etc. If you want to go completely crazy in some super drift competition though, then there is a fuse that you have to remove to completely disable the system, however you will also be disabling your ABS.
StuLax18's Avatar
I'm in the habit of doing it now. I notice if that VDC off is not illuminated.
