Car lost power and it felt like I was running out of gas..
Old Aug 8, 2009 | 06:14 PM
ricerocketdave's Avatar
I was driving on the freeway today going about 65 and the car all of a sudden felt like it was running out of gas. (2004 6MT Coupe Stillen cold air, JWT clutch and flywheel)
I would push the gas pedal and I had no power. It was very intermittant (it would have great power one second then the next noting)
The car never completly died and I was able to make it off of the freeway. Once I got off the freeway the car started acting completly normal, and it has not happened since (put about 10 miles on it since)
I had about 1/4 tank of gas and judging my my previous mileage logs about 70miles left on that tank of gas. When I pulled over I went ahead and filled the car with gas.
Has anyone else ever had this issue? The car has 80,000 miles on it and I do have an extended warranty which is looking like its about to get some good use.
Old Aug 8, 2009 | 06:26 PM
eldgebroni's Avatar
I did, mine turned out to be a bad cam sensor. No error messages?
Old Aug 8, 2009 | 07:05 PM
User 92024's Avatar
Did you get any CEL? The only time my car did something similar was when my throttle position sensor (TPS) went bad on my 2005 Nissan 350Z 6MT. But my car only had about 7000 miles on it. My car suddenly loss power driving it through a parking lot. I shut it off and turned it back on and ran fine but i did have the CEL still on. Took it to the dealer and got a new throttle body.
The only other thing i can think it might be is the MAF sensor. Have you cleaned it recently?
+1 on the extended warranty. I've had door locks, wheel hubs, and my valve body go bad...all replaced for free!
Old Aug 9, 2009 | 01:11 AM
JBF's Avatar
JBF
faulty throttle body. Mine did the exact same thing. if you're still under your PT warranty its covered. Talk to Brad at Grubbs
Old Aug 9, 2009 | 09:43 PM
The weird thing about it is that there is no CEL
I have put about 100+ miles on the car since this has happened and nothing has happened since. I am going to try and get it in the shop this week..
Old Aug 10, 2009 | 05:52 AM
hoodG's Avatar
i had something similiar happen while i was driving.. turned out to be a loose battery connection.. i tighted my negative clamp and cleaned my positive clamp, problem solved..
Old Aug 10, 2009 | 10:57 PM
BlueBOB's Avatar
yikes. looks like you've got a couple good ideas... research away!
Old Aug 11, 2009 | 12:35 PM
BeerViper's Avatar
This sounds similar to when the car goes into limp mode??
Old Aug 11, 2009 | 12:47 PM
User 92024's Avatar
Exactly what my 350Z suffered from. Dealer said my car was in limp mode, but i'm not sure if a car can stay in limp mode with no CEL on? Anyone know if that is possible?
Old Aug 11, 2009 | 10:47 PM
Well the car did it again today. The same exact symptoms.
The main thing that was the same this time as was last time is that I had about 1/4 tank of gas. I was able to limp the car to a gas station. (I could not take it over 2000RPMs in 1st)
Once I put gas in the car it was perfectly fine. My buddy who is a mechanic is going to take a look at it this weekend before I go and spend $100 on my warranty deductable.
We are going to replace the fuel filter, but he said that his bet is that the fuel pump is starting to go.
Old Aug 12, 2009 | 09:29 AM
BlueBOB's Avatar
The only reason I doubt the fuel pump is the fact that your problem would be more intermittent and the details of your problem sound to specific to be something mechanical. By that I mean, I would guess that the computer is detecting the problem and limiting you specifically to a low RPM.
And aren't the fuel filters in the gas tank as well?
Old Aug 12, 2009 | 09:39 AM
JBF's Avatar
JBF
mine did the exact same thing...no CEL but I decided to try and pull codes anyway. I had TPS code and two other codes "pending" Like they fixed themselves instantly or something.
$100 deductible is better than losing power on the highway and not being able to get off to the side in time and getting hit!
Talk to Brad at Grubbs and he'll take care of you. He's probably the best service advisor I've ever dealt with.
Old Aug 12, 2009 | 09:43 AM
BlueBOB's Avatar
Yea, I forgot to mention that as well in my post. Nissan has a history of throwing codes that do not cause the check engine light to come on. It's retarded, but happens
Old Aug 12, 2009 | 10:06 AM
waijai's Avatar
i.love.gold
Yes the fuel filter is just a mesh bag over the fuel pump.
Old Oct 25, 2010 | 12:44 PM
DEMoLITIoN's Avatar
Sorry to revive an old thread, but what ended up being the issue? My car recently started doing this. I was accelerating on to the freeway and when i shifted into 3rd the car would hit rev limit at 2300 rpm. i will try to pull codes today. CEL is not on. I was thinking it was either the spark plugs or fuel pump. It works fine most of the time but this is getting annoying.
RedBaronK
Jul 27, 2015 03:19 PM
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
realtalk21
Jul 20, 2015 09:07 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
