Door Lock Actuators (removal/install)
Old Feb 14, 2010 | 12:15 PM
JD_AND_DA_G_RIDE's Avatar
Question Door Lock Actuators (removal/install) **Update**
Anyone here replace their actuators w/ OEM ones? I'm reading the repair manual and it looks like a pain in da @$$. I gave in and just got both of them..tired of living ghetto fabulous w/ no door locks. Let me know if anyone has changed them or a cheap place for labor although I'd rather do this myself.
And yes, I did a search on the forum but didn't really find any pics/vids on this.
I called my bodyshop I deal with and $80 bucks or so to do both doors, so I'm thinking that's a good price??? Anyone else chime in....
I did call Sewell just to see...$583.10 LABOR ONLY...and I asked again LABOR ONLY...DOOR LOCK?!? Yep...I love Sewell but shhht, are they smoking crack...
Thanks,
JD
Old Feb 14, 2010 | 02:04 PM
vietboi817's Avatar
I did the $5 Door Lock fix, works like a charm. you still have to take your door apart and do some simple fabrications. But you dont have to take the inside part of your door, nor remove the window.
https://g35driver.com/forums/interio...uator-fix.html
Old Feb 17, 2010 | 05:41 PM
Thanx man, but I was actually looking for DIY vid/pics for someone that's actually replaced them w/ new OEM ones. I didn't want to chance it so I get new OEM replacements.
Old Feb 17, 2010 | 06:03 PM
acidjake75's Avatar
Lightbulb
Wish I have done this before - would certainly knock it out for you....and the sewell price...that made me LOL..
Im going to look over the FSM to see whats all unvolved. I bet it aint shiet...Ive taken my doors apart penty of times..
Small fee and some brewsky can easily play some influence here..
Old Feb 17, 2010 | 08:56 PM
ricerocketdave's Avatar
I only did the $5 trick..
I could not justify spending hundreds of dollars on something that I know will break again.
Old Feb 18, 2010 | 07:16 PM
Well mine lasted for a solid 5+ yrs so it was worth the risk for me...lol plus I've read where some ppl have shorted their ECM or whatever it's called and then it ends up being a more costly repair.
Old Mar 24, 2010 | 11:40 AM
BigJasonRR's Avatar
My driver's side was sticking, so I went ahead and got new OEM ones for both driver and passenger side.
I was just searching the forum for a DIY and saw this thread.
JD_AND_DA_G_RIDE - Did you ever figure out how to swap them out?
Thanks.
- BigJason
P.S. I got beers and pizza for anyone who wants to roll up to Flower Mound and help me out. I'm 15min North of DFW airport.
Old Mar 24, 2010 | 01:32 PM
BigJasonRR's Avatar
So I decided to get started and see what I could figure out on my own.
I watched the video tutorial on the window motor replacement, as I figured a lot of the disassembling parts would be the same.
I started with my driver's side, and the video shows the passenger side, but they're totally different. In the video, he simply removes all the fasteners and the interior door panel comes right off. I've got all my fasteners removed and the thing isn't budging. There looks to be 3 thin layers of metal within the door (see pic), and as I try to pull on what appears to be the outside "skin", I get absolutely no movement. I was careful in applying the Dynamat not to cover any seams, and I just put it on a week ago, so I'm pretty sure thats not it.
Any advice??
Thanks!
- BigJason
Attached Thumbnails Door Lock Actuators (removal/install)-dsc05729.jpg   Door Lock Actuators (removal/install)-dsc05732.jpg
Old Mar 24, 2010 | 01:37 PM
GreenGoblin's Avatar
The goblin resurrection
you need to remove the bottom window track bolts also
Old Mar 24, 2010 | 01:47 PM
BigJasonRR's Avatar
Thanks!
I've removed every bolt that I can see. Where are the bolts that you're referring to??
THANKS! I got my whole damn door apart and at this point am committed to getting this thing apart and the new actuator installed!
- BigJason
Old Mar 24, 2010 | 05:30 PM
BigJasonRR's Avatar
Ok...I'm stuck. I've taken out every fastener that I can see and it's still not moving.
HELP!!! PLEASE!!!
Old Mar 24, 2010 | 06:31 PM
BigJasonRR's Avatar
OK...so I'm a moron and Dynamatted over the panel. Problem solved.
- BigJason
Old Mar 24, 2010 | 07:31 PM
vietboi817's Avatar
so remember how i said i did the 5 dollars fix? well that was for the DRIVER'S SIDE, and guess what? now my passenger's side is out. seeing this thread kinda makes me wanna rip my door apart n apply another fix. it's very time consuming. i hated it =/
Old Mar 24, 2010 | 08:07 PM
vp-g's Avatar
you should have paid some one to do it $80 was a good deal IT IS A BITCH!!!!! TO INSTALL. But any way I can help you since I did my passenger side by myself and about to do the driver side.
take apart the door panel which you did.
remove the metal pan take all the screws off
once the inside of the door is expose remove the glass two screws(you can start to use profane language here)
remove the glass rails (use profane language here)
remove the door handle (tricky use profane language here)
remove the door actuator 3 screws (use profane language here)
reinstall the new actuator and reassemble it helps to have a second person to help you with the glass...
I am not looking forward to doing the driver side but have to soon.
Old Mar 24, 2010 | 08:34 PM
alfhasg35's Avatar
there is also a plastic/rubber grommet that you have to remove to expose a STAR headed bolt.. it is located in the door jam. and it holds the door handle on...
