CLUB MODERATOR
Quote:
Originally Posted by sexyrob
haha, I guess I should have taken a picture of that too... it actually is about 10 feet away, begging me to go in.
haha well I may tackle mine here in alittle bit. I got the main wiring harness pulled apart...got some of the ignition coils re-wrapped and tucked away....drivers side is still just a tad short even after pulling...reason its short is because I need to tucked it away up top...looks like i will attempt to solder the headlight harness
the passenger side is good tho right? I extended it a foot so you shouldn't have any issues.
JBF
close
- Join DateDec 2008
- LocationWillow Springs, CA
iTrader Positive Feedback100
iTrader Feedback Score(46)
Liked:688 Times in 367 Posts
Chris, Rob,
was the timing cover a pain in the **** to get off? Also, how much harder would it be to remove it with the radiator installed?
EDIT: nevermind the radiator part. I noticed you have a 350z radiator.
did you get that from OH6G35?
just got back from driving my 2006 x from nashville to idaho and back in the last 5 days... got plenty of snow and it performed perfectly while running for sometimes 30 + hrs straight
Its not hard to do the t/m with the radiator in. First time I did it with the rad and fans out. 2nd time I just pulled the fans out to give me more room
Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
Quote:
How many miles was that??Originally Posted by 615brian
I just ordered a 1000watt Monster dual amplifier kit the 300 series. Really cheap too. Going to wire up all the speakers next weekend.
CLUB MODERATOR
Quote:
yes sir!! Originally Posted by sexyrob
its completed on the passenger side.
Timing cover I think is more time consuiming to remove all the accessories..actual install isnt hard...the most annoying part was scraping off all of the damn permatex leftover after pulling off the original one.Originally Posted by Johnnys_Beast_Foo
Chris, Rob,was the timing cover a pain in the **** to get off? Also, how much harder would it be to remove it with the radiator installed?
correct I have the 350z Koyo right now installed. PLENTY OF ROOM!!! had to undo the core support and lean it back for one of the alternator bolts because it was hitting the motor on the fan.
Rob did learn how much nicer it is to have all the items deleted that he has done since I had all that extra still remaining...
Quote:
correct...KOYO MAKES a big difference in space. Originally Posted by r1forever80
Also I went ahead and started polishing my spacer myself instead of sending it...so far pretty good. need to go and pick up some finer sand paper to perfrom all the detailed work.
before:
After:
you had so much clearance on your loom than i did i couldnt even get the windshield washer resvoir to connect. +1 on the spacer polish.
Frankieg35
close
- Join DateOct 2006
Quote:
It's a long process we just did my buddies and extended every wire.. Well worth it though..Originally Posted by g35man04
CLUB MODERATOR
Quote:
We extended it a ft. wasnt even closeOriginally Posted by gmotion04
Frankieg35
close
- Join DateOct 2006
Can u send me a pic how u ran your wires?? How u ran each connector?? And somewhat of a DIY?? when we put my buddies engine in we have to tuck his main harness..
